Crystal reports version 8.5
When crystal goes to load the rpt file, we get a "too many files open error". We have our software program set to delete .tmp files, but for some reason it not being allowed. Any suggestions for a workaround? Our program is written in Visual Basic and uses Crystal reports as the report engine. Any help would be appreciated. Thanks.
  • ARGE RAJU Jun 04, 2013
    Crystal Report (8.5) is not working on win7/windows 2008 64 bit system My application is a vb application and I am using Crystal report 8.5. It is working fine on 32 bit system and 64 bit system of Windows 2003 server. When I run the same application either on win7 64 bit or on 2008 64 bit, report does not open. I am using vb script to access the database. Part of the code written in the VB script file is as follows: Dim objrsRecordSet 'As RecordSet Dim strSQL 'As String '**** Open Database Connection using the parameters passed from the main program Set dbConnection = CreateObject("ADODB.Connection") dbConnection.ConnectionString = "Provider=SQLOLEDB;Server=" & mstrServer & ";uid=" & mstrUserName _ & ";pwd=" & mstrPassword & ";Database=" & mstrDatabase & ";" dbConnection.Open dbConnection.CommandTimeout = 200 dbConnection.Properties("Enable Fastload").Value = True When i run my application in debug mode it is working fine on windows 7 also. But when i run the application through the set up by consuming the dll of crystal report then it is not working, in this case report is not opening. Please help me out with this issue, i will appreciate for your response.
    Scholar:
  • 64 Answers
I'm not an expert in Crystal Reports, however you might find my info and experiences to be of some use with your question. I've been working with VB6.0 for some time. One day I decided to checkout Visual Studio 2008, (which came with crystal reports) I decided I didn't like it and removed it from my computer. It was after the removal of crystal reports that my computer went to hell. Every program I tried to install since it's removal was not being allowed, also every program I tried to uninstall was not being allowed. After some research I found out that Crystal Reports was the culprit. It has a management package that was designed to protect it's rights management. Simply stated.....it was governing parts of my registry by setting certain parts of my registry key permissions to, "read only". I ended up having to use the administrative tool in Windows XP and reloading default permissions through an existing INF file thus resetting every registry key back to it's default read/write state. I would not recommend you do this. Doing so may harm your existing install of Crystal Reports. What I would do though if I was in your situation, would be to change just the one key that pertains to your .tmp file location in regedit. My guess is it would be located HKLM under software. You can change any key permissions by simply right clicking any key and go to, "permissions" However, if i'm guessing right, Crystal Reports has a backup mech. that would not allow you to change the key permissions even in regedit. In wich case you'll have to use a utility like ::.HERE.:: and create a custom bat file for just that one key. You can try contacting Crystal Reports directly but i'm quite sure they'll just tell you to kindly, "get bent" lol. This method of protection serves no purpose other then to protect their software from being pirated. So i'm 99% sure they won't help you in the matter that you need. Changing permissions to registry keys back to default would negate their program protective measures. From the problem you described i'm 90% sure that is exactly what is going on due to what I already know about the protection measures of Crystal Reports. Any file that is being generated with Crystal Reports, temp or otherwise is now governed by Crystal Reports through your registry, through a registry like firewall, also run by Crystal Reports. This is why you're getting Access Denied when you try to right click the file and delete it locally. You have two options.
1.) Become submissive and a slave to their tech support and wait for them to come up with a solution that will allow them to maintain control over your registry, with a patch of some sort provided by either Microsft Visual Studio or through Crystal Reports directly that will resolve your particular issue.
2.) Setup a dummy computer install all the crystal reports programs on it. Get it all setup, then do a full registry reset (from that link i posted above) and see if you can still use crystal reports after the full registry reset and if that truely resolves all the access conflicts. If so then apply it your main work machine and once again become the master of your registry.
Hope that helps,
9x
Posted on Oct 09, 2008
Acer crystal eye webcam runtime error problem
Try reinstalling your camera driver and application program.
Mar 28, 2012 | Computers & Internet
How to increase the speed of Dot Matrix Printer using CrystalRpts
In the .rpt file select the printer fonts (they will have a printer icon next to them). These will print faster than truetype fonts.
Apr 16, 2010 | OKI MICROLINE® ML390 Matrix Printer
How to make video with crystal eye web cam
hello kma bay bay,
Look for a piece of software called "Acer Crystal Eye webcam" in your start menu program list, or in your program files folder. This is a simple photo and video capture program that comes with your laptop. It is very similar to Apple's "Photo Booth" program if your familiar with that.
To start recording a video click on the camcorder icon, to stop click on it again. To take a picture click on the camera icon. All of your saved photos and videos will be displayed in a scrolling menu along the bottom of the program window. To delete a file click on it to highlight and then click the trash can icon. To open a file in a video player or photo view double click it. If you don't have this software I've included a link to download it from cnet.com below.
If you found this helpful please leave positive feedback, thank you.
Feb 18, 2010 | Acer Aspire 5735 Notebook
Oracle ODBC connection shows no tables in Crystal Reports, procedures only. I used to see them, but no longer. I can in Access so I know it is not the ID.
i am also experiencing this problem. what i did was i created a new file in the repository folder (in crystal, when you create a new connection), containing the script that will pull all of my needed data.
Aug 31, 2009 | Crystal Decisions Crystal Reports Server...
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
HOW CAN I USE Crystal report in asp.net
In visual studio 2005 or 2008 crystal reports is present inside so right click in the project and add new item and select crystal report(.rpt) and select the database samething like gridview connectivity and select the table select row and columns of the table now u r crystal report is ready
Mar 07, 2009 | ComponentOne WebReports For ASP.NET...
I cant find the icon or the word crystal eye to open crystal eye
Click on my computer / ok then click Program files / click crystal eye folder / when you are in that folder see if you see a file that says crystal eye.exe this will run the program.
Let me know if this works
Feb 18, 2009 | Acer Aspire 3610 Notebook
Computers & Internet Logo
1,392 people viewed this question
David Payne
David Payne
