Standing in front of the High chair, on either side of the back of the chair are two plastic pieces, that look like they serve no purpose. They are curved at the bottom, to hold your finger. Place your fingers on the bottom of these two pieces and pull up. Magically, the chair will fold towards you. You can also easily remove the foot rest to get a flatter fold, so that the chair fits into a smaller space.
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
Hi guys, I had this problem when I first got my urban rider - the trick is to put the seat on correctly in the first place. If you look under the front of the seat (when seat is facing away from mum/dad) you'll see 2 plastic hooks - these need to be hooked over the first horizontal bar of three that you can see (it has a small black plastic nobbly bit on it) then, as you were doing, push the handle and pull the 'tube'. If the seat is facing you (child travelling backwards) it won't fold, neither will it fold with the carry cot attached. Hope this helps! Tegans mum x
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
