Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Light Engine Problem with my Hitachi 50v500 - Solution
About two years ago, I had a small red blur in the middle of the screen. That red blur is now all over my screen. I called Hitachi and they said that there's nothing they can do about it because it's almost 4 years old and the warranty has expired. I called a repair shop and they said that it may be a light engine problem and it will cost about $1300 to repair. Might as well get a new TV for that. I did some research and found out that this is a common problem and that you need to be persisting when calling Hitachi and speak to a supervisor. The supervisor said that if a repair person confirms that it's a light engine problem, that they will send the part FREE OF CHARGE (just gotta pay for labor). They will only send a replacement once.
  • 1 more comment
  • Anonymous Sep 21, 2008
    i have a proble with my tv too
    with my light engine
    it wont work
    and it is toooo
    expensive to get it reparied
    what should i do?
    who can i call?
  • Anonymous Jan 21, 2009
    how much was the labor? we have the same problem.
  • Anonymous May 02, 2009
    Everything on my 50v500 was pink/red. Started researching for a new TV, tried this fix, and everthing is back to normal. Thanks!
  • 11 Answers
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
  • larry starratt Oct 18, 2011
    lstarratt11 wrote:
    What data settings And adjustment values what dat settings/ adjustment values am I recording before I implement memory initiation?
  • 3 Answers
Http://www.angelreyesblog.com/2008/08/articles/lawsuits-and-verdicts/hitachi-class-action-lawsuit-filed-by-horpb/
Here is a web site for a class action lawsuit against Hitachi for the 50V500
Posted on Oct 26, 2008
    What data settings And adjustment values am I recording before I implement memory initiation?
HELP ME!!
find the light engine for hitachi 50v500 tv
who sells them and where can i get them LESS
expensive?????????????????????????????
Posted on Sep 21, 2008
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
Nov 27, 2015 | Hitachi Televison & Video
Red tint to screen
If the model is a 50v500 the real question should be does the set have a red oval area in the middle of the screen (entire screen not red)---if the entire screen is red you have a chance---it has a red oval area and it needs a new optical light engine----you will have options also but limited if that is the case.
Aug 26, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Apr 20, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a red glow in the middle of the screen and the color is dim. It has been gradually getting worse as the year has gone on. Is this a bulb issue or a convergence issue?
This is light engine issue, light engine produce image and project it front screen of TV.
I'm afraid light engine replacement would cost you much, $1000 plus, check with local tech for estimate.
Thanks.
Dec 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V 500 LCD Rear Projection TV
Aug 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
New light engine
Aug 25, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi Class Action Lawsuit
I have a Hitachi 50V710 with a yellow-greenish spot in the center of the screen. It appeared there about a year ago. I have been putting off getting it repaired because money has been pretty tight. And they told me that my warranty has expired. They also said that it would cost over a thousand dollars to fix the problem. I purchased the 50" TV 09/09/04 for a total of $3336.88 what a rip-off. Now the whole screen has a green tint and the yellow-greenish circle in the center looks brighter. I wonder if it is even worth getting it fixed? What will go wrong with it next? Its a Lemon.
I really regret not buying the 52" sharp that was setting next the piece of **** that got suckered into buying. I know I learned one thing out of this,
" I WILL NEVER BUY HITACHI BRAND PRODUCTS AGAIN! "
Aug 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500a high definition tv
Jul 25, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red blurred area
I had whole redish/pink screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
1. Enter the I2C Service Menu, be sure the power is OFF.
2. On the front control panel, press and hold the INPUT button.
3. Then press the POWER button for two seconds.
1. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
2. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
3. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
4. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
5. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
6. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
7. Turn the set off-on and Confirm the picture remains in a good condition.
May 14, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Problem
It is a failure in the light engine itself. You will need to have it replaced. Here is a link to that rather costly part. http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50V500/Hitachi+Ltd/Hitachi/UX22201D/New.aspx
Apr 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
1,876 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
