Question about Zebra Eltron P420C Printer
How do I reset the card-print counter on an Eltron P420C
I've replaced the printhead on an Zebra/Eltron P420C ID Card-Printer.
However, I was hoping someone could tell me how to reset the existing `card print count` to zero.
I've selected `Properties` of the printer but don't seem to see the option to do this, even though I have saw the option before on another P420C on a different PC, i.e. via the properties it shows a tab to click to `Reset Card Count`. I can't seem to find it though on my own set-up.
Many Thanks in anticipation!!
  • eydarkside Dec 16, 2008
    i have same problem with zebra p420i if somebody know please help us
  • 185 Answers
U select the properties and search for tabs like card count,details etc and reset thecount to not sure about this answer this may work or may not be.
Posted on Aug 26, 2008
There are long axis print voids. Does the print head need to be replaced?
Before replacing your printhead, try cleaning the printer, run the cleaning card and also clean the printhead using the alcohol saturated swab, zebra part number 105909-169. In some cases that will fix your issue, if not your printhead needs to be replaced. If replacing your printhead, please make sure your card stock are clean and don't have sharp edges as that could be the cause for a scratched/burned pixel on the printhead.
-- The Pros at
Sep 22, 2011 | Zebra Eltron P310 Thermal Printer
Controlador de impresora zebra modelo p420c
Saludos. Conseguiste el driver para windows 7?
Jan 07, 2011 | Zebra Eltron P420C Printer
Zebra p330i
lose the two screws from the front plate, put a card under the printhead, ajust the plate on tope of the card, tie the screws. send a command !SA from the driver, and print a test card (send IM command)
Jun 21, 2010 | Zebra Eltron P330i Card Printer
Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Jan 21, 2010 | Zebra Eltron P420C Printer
How do I replace the printhead on a Zebra P330i card printer
If there is a problem with the printhead you have to send it back to Zebra for repair. The zebra website has info on how to send back printers for service.
Dec 02, 2009 | Zebra Eltron P330i Card Printer
The Zebra P420C printer was working fine then it would not print any cards. The unit was cleaned and a print head replaced the unit will still not print any solutions. SN611182 (newer style)
try going into the hardware install/removal wizard or into device manager to remove and reinstall the driver for the unit this may help.
Oct 02, 2009 | Zebra Eltron P420C Printer
Printer not printer well
Check if ribbon is placed correctly, a lot of cheap pvc cards are low quality and have distortion on the faces, you can check them by seeing reflection light al the sides, if misprinted area have a constant pattern the check rollers, if lines appear in the printed cards in the same place a long the card then the printhead is damaged.
Sep 21, 2008 | Zebra Eltron P330i Card Printer
Ribbon Breakage
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Jul 10, 2008 | Zebra Eltron P310I Thermal Card Printer
Have you cleaned the printhead yet? If it is easy to get to. Use some alcohol and cotton cloth.
Aug 09, 2007 | Zebra Eltron P330i Card Printer
Zebra Eltron P420C Printer Logo
342 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
