Question about Frigidaire 36" Built-In Electric Cooktop - Black
Ceramic cooktop 4 element +warmer, model #FEC36S8HBA
Hi, one of the burners/elements will not turn off unless I push and/or repeatedly turn the knob several to many times. And at that point I still don't know if it's turned off completely because of the burner indicator still being lit up for 20-30 minutes after turning the know to OFF.
If you know the problem, can I order parts to fix it myself?
Thanks, Elaine
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Whirpool cooktop element does not heat right
Replace the surface element switch.
Posted on Feb 22, 2009
  • 1462 Answers
SOURCE: Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Posted on Nov 20, 2008
Maytag317
  • 1136 Answers
SOURCE: I cannot REPLACEMENT KNOBS fOR model # 5D02
Hi, The part #74009592 for your knobs. This # is for a black knob. Let me know if I can assist you further.
Vic
Posted on May 24, 2009
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
Westinghouse freestyle 521 stove ceramic top.elements wont turn down no matter where switch is. burns food. Have used different size pans etc,
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
May 29, 2010 | Cooktops
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Nov 20, 2008 | Frigidaire Cooktops
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
Frigidaire 36" Built-In Electric Cooktop - Black Logo
173 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
