Question about Casio Cassiopeia PA-2400W
Cassiopeia 2400 HELP (modem, cables, network cards?)
I have recently acquired a Cassiopeia 2400W (ce 2.0) Can anyone tell me what pcmcia modems will work with it (and where to get drivers!) Also what if any network cards work with it, and wether cables and a new stylus are available from anywhere?!? I love the toy, just need some more bits Cheers!
2 Suggested Answers
vega
  • 551 Answers
SOURCE: E-105G System error?
Apparently the device worked before you attempted to install Quake1. So component wise all should be well. One more thing you can try is to remove both batteries & leave it for a while. Install the main battery & then the Backup battery. Before starting make sure the main battery is fully charged. Now try to start the device & hopefully it should boot normally. If it freezes at the starting screen, very definitely something is not making proper contact inside the device & perhaps you should check out the connections within the device following the disassembly instructions at the pocketpcpassion site.
Posted on Sep 06, 2005
SOURCE: Trouble with installing Windows CE
You do not install Windows CE, it is built into the Cassiopeia. What the CD is is the software for your computer to interact with the Cassiopeia.
You will want http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Posted on Mar 14, 2008
0 characters
1 Points
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Mobilepro 900c Ethernet Card
I use the AVAYA wireless card. It needs to be wireless B. Dowload the driver for it when you sync. Then it should work.
Aug 21, 2007 | NEC MobilePro 900c Pocket PC
Instruction Manual
check out http://www.ia.nrcs.usda.gov/Technical/gis/pda.html go down the page to the cassioppeia 2400 section et lioa la (or some such stupid saying in french)
May 30, 2007 | Casio Cassiopeia PA-2400W
May 08, 2007 | Casio Cassiopeia E-100 Pocket PC
Jornada 820 - WiFi cards HELP
Can you try inserting the card and resetting the unit with the reset button. When the unit is back up got to start>programs>communications>remote networking then make a new connection. Choose dial up connection and select your card.
Sep 12, 2005 | HP Jornada 820
MemoryCard problems on one CE 2
Hello, Check that you formatted it with FAT (not FAT32 or NTFS). If not, format it again with this file system (FAT). I think it will resolve the problem.
Sep 06, 2005 | Casio Cassiopeia PA-2400W
E 115 and windows ce?
Tascal software has a software for changing the wallpaper on the CE devices. File name is wpc032mp.zip. Try it.
Sep 06, 2005 | Casio Cassiopeia E-115
Casio PA 2400W
No, No, No I'm afraid. This thing can't hack it when it comes to the power required to download mp3 files. Maybe some /really/ lo-fi midi or such, but nothing plesant.
Sep 05, 2005 | Casio Cassiopeia PA-2400W
E-125 connecting to Siemens ME 45
There are 2 things you could try. If you have a serial data cable for both the devices try using a nul modem (Casio part # SB-91 includes best nul modem ever made ) & select Hayes compatible on serial port on E-125. If you have a built in modem in ME-45 it should work. Similarly you could use MS Outlook as an intermediary for transferring your E-125 telephone numbers to ME-45.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Cassiopeia E100, is there anyway to view excel files?
Yes there certainly is. Get SpreadCe programme from ByeDesign. It can handle .xls files upto & including Office 2K in native format. Have no experience with Office XP. As a matter of fact I find it better than Pocket Excel included in CE 3.0 and later. I store my files under My Documents folder on the CF card using a USB card reader/writer. Hope this helps.
Sep 04, 2005 | Casio Cassiopeia E-100 Pocket PC
Casio Cassiopeia PA-2400W Logo
Top Casio PDAs Experts
k24674
Are you a Casio PDA Expert? Answer questions, earn points and help others
