Question about Epson Stylus 1400 InkJet Photo Printer
I DO EVERY THING THE WAY I AM SUPOSE TO
BUT STILL DOES NOT REALIZE THE PRINTER IS HOOKED UP HAVE NO IDEA ABOUT TO SEND IT BACK AND GET ANOTHER TYPE OF PRINTER WHAT CAN I DO
Took my time and had to move it to computer upstairs wont work down stairs o well Jim thank you any way
Posted on Sep 02, 2008
Cx5000 only prints headers why?
hello M,Nelson
I gonna need a little bit more information , but i supose it's a personal printer and you dont share it over your Network.
the solution is simple, close your printer and take the power cable off, after close your computer.
plug back the power cord for your printer and re-open your computer.
it's supose to do the trick. let me know.
look for the ink level, a simple way to notice if it is the printer or the computer the problem, try to print a test page.
Oct 21, 2016 | Office Equipment & Supplies
Canon mf4150 -- fax has a mind of its own?
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
I cant send any messages keeps saying hook uo to
Switch off your broadband connection for ten seconds and try to switch it back on. Go to control panel and click Internet connection as soon as wizard displays. Examine if the settings is enabled. Close the control panel and open run command and type cmd. After typing, when it prompts a command, type ipconfig and see if IP address and provider is listed with gateway and subnet. If it has all the addresses, so you can connect back to GMAIL. Thanks.
Jun 20, 2009 | Google Gmail
HELP WERE THIS PART
You weren't supose to take it apart. In the manual it said it's a laser flash one product and now the only thing you can do is tell Nintendo. But hopefuly some will find out.
Apr 20, 2009 | Nintendo Wii Console
Fax won't connect
double check your settings in fax!!! thats all folks
Apr 17, 2008 | HP Laserjet M2727nf Multifunction Printer
Okic3200n lazer jet printer
Best results will be if the paper you are using is designed for use in this machine and you print with the driver knowing paper type and using a direct flat paper path
Use The bypass tray (and you can also use face up delivery tray ) and make sure you tell printer what paper type it is using ie control panel, printers, preferences, paper type set to photo/gloosy or even card stock if it is thick.
Ensure feed rollers are clean, and paper is good quality
Dec 23, 2007 | OKI C3200n Led Printer
NetPrint 1000
Hello everyone,
I've spent the past several hours getting my NetPrint print servers to work on my network & print from Windows XP.
Guess what? I've got the solution.
I have both the NetPrint 50 model and the NetPrint 1000 model. I only got the NetPrint 50 to work. I think my NetPrint 1000 may be shot. Also realize that there were a number of company acquisitions (DPI / Digital Product Inc., Osicom, Sorrento), so there is little to no information left on the Internet regarding these print servers.
Here is what you need to know:
1.) Take the cover off the print server. On the left and right sides there is a little tab that holds the case together. Get a flat-head screwdriver and apply it to either the left or right side along the seam.
2.) Jumper pins. On the NetPrint 50 you want: Auto; 10BaseT. On the NetPrint 1000 you want: 10BaseT; Auto; Tx; Factory (Jumper 10). Remember, I couldn't get my NetPrint 1000 working.
3.) IP Address. The NetPrint print servers use BOOTP to obtain an IP address. Realize - this is an older version of DHCP, but NOT the same thing as DHCP. Some DHCP servers are backwards compatible and support BOOTP. Fat chance, though. My wireless router only has a DHCP server. So, obtaining an IP address automatically is likely far too difficult / impossible. What you will need to do is assign an IP address to the unit. We cannot use DHCP to do this, and we cannot remotely access the unit (web server / Port 80 is not listening on my units). To assign an IP address to your unit, open up a DOS / CMD prompt (Start->Run; type: "cmd" and hit OK). We will be using the ARP command, which stands for Address Resolution Protocol. This is the protocol that translates between IP addresses and MAC addresses.
a.) Select an IP address you want to assign to the unit
b.) Ok, now look at the bottom of your unit and find the MAC address; it begins with two zeros.
Now enter this command:
arp -s 192.168.0.16 00-40-AF-18-61-40
replace 192.168.0.16 with the IP address you want to assign to the unit. Replace 00-40-AF-18-61-40 with the MAC address found on the bottom of our unit.
What we just did was tell your computer that anytime we send data to that IP address, it will actually send it to that MAC address, which is your unit. Ok, good job.
Now type: arp -a
and you should see and verify your entry. If you made a mistake, type: arp -d 192.168.0.16 to remove your entry.
Now, your NetPrint print server has no idea it's just been assigned an address. And it won't know to respond to that IP address unless we make it listen on that IP address. This is easy to do. All you have to do is ping the unit. Don't worry if the unit does not reply to your pings. Simply pinging it will make it realize it needs to listen on that IP address. So, type this command:
ping 192.168.0.16
Done. It's now listening on the IP address you just assigned it.
4.) Setup Printer in Windows XP. Ok, go to Control Panel -> Printers and Faxes. Add a Printer, select a Local Printer (uncheck plug-and-play). When it asks you to select a Printer Port (it will default to LPT1)... select Create New Port -> Standard TCP/IP Port. Hit Next. Now it will ask you for the Printer IP Address and Port Name: Enter the IP address you just assigned to your unit; the Port Name can be anything you want... this is just a string that uniquely identifies this printer port on your computer and it has nothing to do with the printer or print server itself (I used "RyansNetPrint"). If it asks you for what type of Network card, just select Generic. Select the Printer driver for the printer you have hooked up to your NetPrint print server.
5.) Setup LPR & Queue Name. We need to reconfigure this for it to work. Ok, Now under Control Panel->Printers and Faxes - right-click on your newly created printer and hit Properties. Click on the Ports tab. Highlight your newly created printer port (ie, RyansNetPrint) and the Configure Port button. Windows defaults the Protocol to RAW. This won't work on your NetPrint print servers. You need to select LPR. Now, the one last thing you need to do is enter the proper Queue Name. The Queue Name format is: "PORTn" Where n is the Port Number (probably 1 or 2) on your NetPrint print server where you connected your printer cable. My NetPrint 50 only has one port, so my Queue Name is "PORT1". This is where I found the Queue Name information: "http://www.brooksnet.com/faq/210-04.html". Realize - I couldn't get my NetPrint 1000 to work properly. I think it uses different Queue Names. For instance, I tried "PORT10001", "10001", etc... to no avail. I gave up and used my NetPrint 50 since it worked easily with the instructions I just gave you.
Now hit OK, click on the General tab, and click Print Test Page. Walaa!
Hope this helps you. Took me a long time to figure all this out.
Ryan
PS. the arp -s command is only peformed on your local computer. When you ping your unit. When you reboot yoru computer, the arp -s record your created will disappear. So, they key here is - my wireless router remembers what IP address goes to what MAC address (because I pinged it). Now, if my wireless router is powered off - it forgets that information. So - if you reboot your wireless router / network router / switch / hub... you will need to reenter the arp -s command and ping your NetPrint print server again to assign the IP address again. Not perfect, but it works.
Oct 28, 2007 | Osicom NetPrint 1000 Print Server
Epson Stylus  1400 InkJet Photo Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
