Question about Canon PIXMA MP210 Photo All-In-One Printer
Mp210 all-in-one printer
When the roller goes to feed the paper into the printer, the paper crunches up and will not procede through. This printer is brand new, it wokred once and then stopped. PLEASE HELP!
  • Anonymous Sep 21, 2008
    Same issue for me.  It grabs the right side of the paper and pulls the paper in crooked, causing a jam.  I never have gotten it to work correctly.
Contact Canon and they should arrange for it to be replaced. They got me t send it to the "service centre" but i just got sent a new one within a couple of weeks of sending.
I have been told that my postage costs for sending it back to them will be reimbursed, but am still waiting. Have had the new printer back for a couple of weeks now, so will start nagging them until I get my cheque!
Posted on Aug 27, 2008
Canon MP210 takes paper crooked and spits out crooked or jams. How to fix? Followed manual for cleaning feed roller but to no avail. Thanks
could it be a paper clip fell into the paper feed slot? see if you can shine some light into the slot and use a dentist's angled mirror to examine. sound like debris may be the culprit. disassemble it to the extent that you have ability to. LEARN THAT WAY!
Feb 12, 2015 | Canon PIXMA MP210 Photo All-In-One Printer
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Paper wont feed straight and goes to error
Hi
You must have a paper jam somewhere in the paper path.
Remove all the paper, gentle rotate rollers and make sure there is nothing.
Also remove all covers that flip and check for obstruction.
Please dont forget to vote this answer was helpful and accept solution.
Many thanks
Feb 20, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My canon pixma MP210, is not feeding the paper through, seems to jam, but printer still is printing. The paper is taken about 10cms into printer, then twists slightly but does not fee through. Have checked...
There is a foreign object in the paper tray. Because it is curved you cannot see it. It is stuck in the narrowed area right before the feeding rollers.
Disconnect the cables and rotate the printer in a way it stands on its back.
Open the front cover. Use long thin flat screw driver that can go trough the paper out area and to reach the feed roller.Insert the screw driver between each pressure roller and the the feed roller to release the object. If successful it will fall out from the tray. Usually it's a coin, pen, point-protector, ruller, paper clip and so on.
Aug 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feeds only from left side and gets jammed
Looks like the feeding mechanism is stuffed.
Perhaps try and get a broken one of some trade website and replace the mechanism, but MP210 is pretty cheap model this days and my personal recomendation is to bin this printer and buy new one.
It will save you some time and frustration.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
The paper will not feed in all the way. it starts
The paper feed roller needs to be cleaned, you will have to take the printer in for a service.
Aug 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Roller Cleaning is completed.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
49 people viewed this question
old marine
old marine
