Moved computer... now when botting up....I get the following message
If you can read this message, Windows has successfully
initialized this display adapter.
To use this adapter as part of your Windows desktop, open
the Display option in the Control Panel and adjust the
settings on the Settings tab.
But the problem is that this message never goes away. Even after Windows loads (I can hear it) the message is still there.
    Brigadier General:
  • 10,406 Answers
Just "close" the message-window, after performing the indicated actions.
Posted on Dec 03, 2009
When i start up it goes to a black screen and says: For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check Cable Connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting...
You may try booting in safemode.
Follow the steps:
1. Turn the computer on or Restart the computer
* Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
* Ensure that the Safe mode option is selected (the top option)
* Press Enter. The computer then begins to start in Safe mode.
2. Do system restore. Follow the steps tp://support.microsoft.com/kb/948247. If it do the same thing go to 3.
3. Recovery.
Actually that error is an indication of some bad sectors on the Hard drive. There is still no guarantee that the recovery will work.
Mar 01, 2011 | Computers & Internet
Tip
Gtalk Bot Trick
This is a cool Gtalk trick just add imfeeds@gmail.com bot as a Google Talk contact.
Send the IM Feeds contact the message "join" and follow the directions.
This will allow you to read any website that syndicates content via RSS feeds.
Cool ain't it?
on Sep 22, 2008 | Google Talk
My digicam lens keeps on moving... coming in and coming out and the screen says "ACCES"
The ACCESS error message displays when there is an internal malfunction or a malfunction with the Lens. This may also appear when accessing the Memory Stick for reading or writing the data. If the Lens is moving in and out then follow the steps mentioned below. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 19, 2011 | Sony CyberShot DSCS750 Digital Camera
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
Windows failed to start
You need to re-install windows mate.
May 20, 2010 | Toshiba Satellite A305-S6852 Notebook
Im trying to install windows vista but its not leting me its saying "this computers hardware may not support botting to this disk ensure that the disl controller is enabled in the computer bios menu"
To resolve this problem, follow these steps:
  1. Create one or more partitions on all the hard disks that are not initialized.
  2. Restart the computer.
  3. Install Windows Vista.
Microsoft Support Link to article
Jan 12, 2010 | Dell Dimension 2400 PC Desktop
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Problem with computer.need to put everything to factory settings. i have windows xp
If you want to put everything to factory settings, then just restore Windows XP to the installation date or the date of purchase of your Computer.To restore the computer follow these steps. Navigate to
1.) Start--> All Programs---> Accessories--> System Tools ----> System Restore. 2) Open System Restore tool and then move back to the initial installation of your Operating System. Click the "Back" on the calender displayed. 3) When the installation month is displayed you can see some bold or highlighted dates. 4) Click any highlighted Day and then Press "Next" . Now the System Restore will be performed and the system restarts. 5) After the system restart you will be notified of a successful restoration completed. In the above way you can put the factory settings of the operating system.
Nov 07, 2009 | Dell Dimension 2400 PC Desktop
Uninstall Problem
If you are installing the software using Windows and the software was not successfully installed or the uninstaller could not be found, run the Scrubber Utility to perform a clean driver uninstallation Use the Scrubber Utility Use the following steps to run the Scrubber Utility.
  1. Disconnect the printer from the computer.
  3. Insert the Starter CD into the CD drive. If the CD menu displays, close the CD menu.
  4. Locate the Utils\Scrubber folder on the Starter CD.
    • For Windows 98 and Windows Me, use the scrub9x.exe file located in the Utils\Scrubber\Win9x_Me folder.
    • For Windows 2000 and later, use the scrub2k.exe file located in the Utils\Scrubber\Win2k_XP folder.
  5. Double-click the file to run the Scrubber Utility.
  6. The following message will display: This utility will attempt to remove all HP DeskJet 460 Series devices from your system. It is recommended that you disconnect the device and restart before continuing. Do you want to continue without rebooting?
  7. Click Yes . A message stating Successfully removed the devices(s)! This system is ready for installation displays after the scrubber utility finishes running.
  8. Click OK .
  9. Restart your computer, and then reinstall the printer software
Apr 27, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
