Hi, please help.
I purchased this DVD/Video combo to do many things. It copies video to DVD easily but I can't get it to copy recorded programmes from my sky+ planner. I've tried the sky copy feature which looks like its running properly but when I check the DVD ram disc it's just a blank screen. I know the disc is not the problem.
For some reason if I am in DVD mode when I scoll through prog/trk to find sky+ it is full of lines and strange colours and doesn't look tuned. I can't change through sky+ channels using the samsung remote. Despite something being on the screen it still records a black screen.
If I'm watching sky+ and press record on the DVD it again records a black screen.
I must have tried 20 different combinations of cables through the tv's scarts and DVD player but I just can't figure this out!
can anyone out there tell me where I'm going wrong.
Thanks
Nick
I think its the dvd players internal settings that need to be adjusted. If there is a menu set the sky box to the connection it is plugged into. Although this might sound strange some units when you connect them up will play fine through that input but unless the settings of the player is adjusted iut will record a blank screen because its default setting for recording might not be either the connection method you are using or the input you are using. I hope this makes sense.
