To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver. 1. You need to sign up with an Internet service provider. 2. Connect a LAN cable from your computer to the DSL or cable modem 3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions. 4. Install Internet Explorer if it has not been done. 5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
<p>The HTC Touch Pro smartphone 2 is avaialble for T-Mobile and
Sprint subscribers, and uses the data network cell phone to connect to the
Internet. While the Internet connection is based on a strong 3G connection for
fast browsing, you can also activate the Wi-Fi device to connect to a wireless
network. Available Wi-Fi networks within range of the Touch Pro will be
displayed on the device are on the list of networks. Once connected, your
Internet speed is capable of data based on the strength of the wireless signal
to send. <br />
<p><br />
<p>1. Slide your finger on the "Home" screen to the
tab "Settings" appears. Play the "Communications" button. <br />
<p><br />
<p>2. Touch "Wi-Fi" on the phone screen, then hit the
wireless network is displayed in the "Discovered Networks" list. <br />
<p><br />
<p>3. Type the network security key using the onscreen
keyboard, and press "Done" for the network to connect. A wireless
signal appears at the top of your phone screen when connected to Wi-Fi network
successfully <br />
<p>4. Touch "Back" to return to the
"Communications" menu. <br />
<p><br />
<p>5. Play the "ON / OFF" in
"communication" from the menu for Wi-Fi off. It is important to turn
off the Wi-Fi functionality when not connected to a wireless network, because
this mode the battery is not on. <br />
2) login using the username "admin" and leaving password BLANK
3) Once logged in, click on the wireless tab and it should have your wireless keys listed.
(this must be done while connected, so if all your computers are wireless, and you dont have the key, you must hard wire one computer and use it to do this.)
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
what u can try is that install the lynksis cd on the computer and then open the network connection and then right click on the wireless network connection and then click on the view available network and then connect to ur network connection and it should work or else the best way u can do is that u can call up dell technical support and they will be definately able to help u to connect to internet cause i really cannot explain all the details here cause it need to be done troubleshooting on ur computer practically by connecting the router with the laptop with the ethernet cable and when u connect the internet with the ethernet cable then the dell guys can take the remote session in ur computer so that they can help u to connect to internet wirelessly.
follow 4 steps to connect to lynksis:-
In order to follow thesen four steps all u need to do is that just follow this link very caarefully and u will definate;y be able to connect to internet wirelessly with the lynksis..
Does it say limited connection to network? You're connecting it through a wireless router right? Do you see your wireless router when you search for networks? I had similar problem with my previous Dell laptop. Wireless use to work untill one day it just stopped, found the networks, but kept giving me limited connection whenever i tried to connect. I found out the problem is linked with the driver. Dell laptop i had was also on XP OS. Maybe try reinstalling the drivers. After I formatted my computer and reinstalled drivers, it started working again. Hope this helps.
There's no way a USB can cause this problem...Its got nothing to do with network adapters unless internet connection uses a USB powered Wireless Network Adapter..
