Question about Maytag Atlantis MAV6000 Top Load Washer
Cold water Maytag washer model MAV6200AWW (doesn't show in your list of products)...also...when selecting colors/whites...the color cycle stops just before spin cycle and just sits there..white cycle runs completely...thanks
  • 1,028 Answers
Ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Posted on Aug 28, 2008
Why does my ge washer model wvsr1060g2ww not work when i select to wash whites, but works when i select to wash colors?
colors uses a cold water cycle and whites use a hot water cycle so you may have a bad water inlet valve where the the hot water coil has went bad or is clogged with debris? u can check it with a meter for OHMS and for 120 volts both test are important. MACHINE MUST BE PLUGGED IN WHEN DOING VOLT TEST SO BE VERY CAREFUL AND TRY TO USE ALIGATOR CLIPS ON UR METER
May 17, 2015 | GE Washing Machines
Slow leak under unit cannot find problem. what specific should i look for?
It is most likely a hose connection from the pump to drain. What you could do is fill up the washer with cold water and color the water with food coloring let the washer rn thru a cycle. on its completion of the wash cycle and after it drains do not let it fill back up. Turn the water supply taps off and til the washer over on its front. With a tissue,(white), find the spot arond the connections where the color has dripped from. Repair that conection and with the washer back uprite run thru a complete cycle to test for leaks as well to purge the color out of the system. You either must do the later or run like h--l if the wife gets that color on her clothes. lol
Sep 28, 2010 | Kenmore 23822 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
I bought this washer used with out a manuel. I
Hello-I came across this several years ago. Some whirlpools have a preprogram where the water temp. is already defaulted to the type of load and color. As you assume the white should be hot or warm. The rest of the selections are probably cold. The manufactures can be driven to apply energy saving features into their products so most cycles are probably cold. If all else fails, when you make a selection let water fill into the tub about 5 minutes and carefully check to see if the water is warmer or colder. You also might be able to pull up owners info on the net if you have the model#.
Feb 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
Maytag mav6200aww washing machine doesn't rinse clothes
If you say this only happens on the Colors and Whites cycle i dont see what the lid switch or balance sensor (if your washer has one) would have to do with it. It does seem like it has something to do with the timer,,, it really sounds like maybe the (Colors & Whites) section of the timer is malfunctioning. Inside the timer, there are a series of gears and switches, and by slamming the lid, or tapping on the timer control knob,,, it could maybe help the damaged part of the gear move, temporarily "fixing" the problem
Mar 13, 2009 | Maytag MAV6200 Top Load Washer
White spots on color clothes
try using calgon tablets, they flush out washing machine for limescale, perhaps it will work for you
Jul 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
