Question about Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort +
After warming up the water the machine discharges to mutch water
The caffee waste drops down to vet not been pressed corectly
  • 515 Answers
How old are your machine?
What number is the grinder on?
How often do descale the machine?
/Mirran
Posted on Aug 26, 2008
I have a saeco magic comfort +. It is, all of a sudden, not going thru the rinse upon set up. Then, it is not putting water thru the grinds, and, thus, pushing all grinds dry to waste, not generating...
Hi
Don't really like the rinse cycle because it waste water. If you want to rinse the brew unit just push the "scoop button" and not put any coffee in, then push the large coffee. Does the same thing but doesn't use as much water.
Dry grounds is one of my tips.
http://www.fixya.com/support/r4084157-dumping_dry_grounds_not_making_coffee
Jul 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
How to descale machine-is there a video showing how? I have the Saeco Magic Comfort + machine.
Hi
I put this next statement in so your machine will last longer.
Enter the menu by pressing the menu button. Scroll down until you reach "water hardness" and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to "Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Feb 14, 2011 | Saeco Magic Comfort Plus Espresso Machine
It says 'ventilate' and nothing works. I have tried to turn it off and back on but it doesn't work.
Hi
Like the Royal Pro machine and Royal Coffee, there is a water button on the Comfort that you need to press to run water. If when you press it and nothing happens you have a stuck solenoid, probably from scale build up. See what happens when you push the button with the drop of water or it may have many drops depending.
Dec 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
How to ventilate Saeco Magic Comfort + coffe maker
Hi
If its a Magic Comfort + there is a water button on the panel (with the drop) that you push for water. You twist the dial for steam only.
If its a Magic Delux you twist the dial for water.
Nov 21, 2010 | Saeco Magic Comfort Plus Espresso Machine
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
May 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
We dont have a manual for our Saeco Magic comfort coffee machine and the declcify message is up on the screen. What do we do?
Hi
Enter the menu by pressing the menu button. Scroll down until you reach “water hardness” and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to “Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process andwhen it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to “reset descale”, push the enter button and chose “Yes” and push the enter button. Now it will tell you we next to be descaled.
Apr 20, 2010 | Saeco Magic Comfort 103467 Espresso...
My saeco magic coffee machine says ventilate.How do I do this?
Hi
If it is just a Magic Delux, open the steam knob, without pushing the steam button. If its a Magic Comfort you have to push the button with the drops on it and it will flow water.
Apr 10, 2010 | Saeco Magic De Luxe Espresso Machine
Rinsing...Warming UP... message on Saeco Magic Comfort plus
HI, I am sure you have solved your problem, however:
If you Descale the machine and let it Rinse to complettion of the
cycle; it resets the machine and it will start Rinising after warmup.
Otherwise press the Menu button and go to Energy Saving
then press the Esc buttton. This allows the machine to start
without Rinsing. Also you may turn Rinsing to Off in the Menu.
Nov 04, 2008 | Saeco Magic Comfort Plus Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
144 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
