I have a TLP-S10 that got a fan error after I blew air through it to remove dust. I opened it all up and determined that all the fans actually work so i'm stumped. If you have the same projector with the same or different problem send me a personal email ([email protected]) and maybe we can help each other. Thanks! :)
Thats good advice, do you have any suggestions for removing the two fans that are on either side of the lens? The circuit board on top of it has ribbon cables that cannot be unattached. Also, do you happen to know the exact location of the air flow sensors? Are they inside the fan? How do you recommend I clean them? Thanks a bunch! :)
I have a similar problem with the TLP-S10. Plug unit in, press on button, start-up screen appears for 5 seconds and then projector shuts down.
Fans remain running and "lamp" and "on" lights turn red. Once unit cools down i can start the process over again but the results always remain the same. I am prepared to purchase an new bulb, but am not sure that the bulb is the problem.
