Question about Whirlpool ET1MTKXKQ White 20.9 Cu. Ft. Refrigerator with Freezer on Top, Reversible Door Swing with ...
Whirlpool Designer Style Refrigerator
20.8 Cu Ft
Model ET21DKXDW
I bought this used for my tenant. The tenant says it is not cooling. They say the freezer works, but the fridge is not cooling.
fridgetech
  • 473 Answers
SOURCE: Kenmore 65092 Refrigerator
This fan will be running anytime the compressor is running. If it isn't then it has failed and will need to be replaced.
Posted on Nov 12, 2007
SOURCE: WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
Possibly freezer drain blocked causing ice build-up behind back freezer wall. This internal wall should be accessible by removing screws.Check fan motor in that area is working and also check that all door seals have no cracks or tears. This can cause ice build-up and motor to run longer than normally. benham's suggestion another possibility.Naturally have power off when dismantling anything.
Posted on Jan 11, 2008
bobotfel
  • 236 Answers
SOURCE: brand new refrigerator...freezer works great, fridge does not
Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
sample of air vent location :
Posted on Apr 07, 2008
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
  • 93 Answers
SOURCE: What temperature should we set the refrigerator and the freezer?
Totally up to you. Most people set them for the temp they like their milk and the firmness of their icecream
Posted on Sep 13, 2009
I have a whirlpool designer 20 refrigerator, it is collecting water at the bottom. What is going on? How can I fix it?
In the freezer, under the cooling coil, is a drain pan that collects water after the coil defrosts. The drain opening from this pan is probably plugged with debris. If you can find the drain line under neath the refrigerator and blow through it, this will usually clear it.
Oct 09, 2014 | Whirlpool Refrigerators
Whirlpool Gold GB2SHTXTS00, I bought it in 2007, but 3 days ago, the cooling suddenly is not working, but freezer and lights are fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
My refrigerator is no longer cooling. It runs fine, the coils are clean and their appears to be no leak of any refrigerant. Please let me kno what else I should check.
This video will explain how to repair this style refrigerator
You can also read more articles @ http://www.appliancerepairlesson.com/
Feb 26, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
Could be defrost sticking or the compressor not starting...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a whirlpool designer style refrigerator that is leaking inside how can I fix it
you have to check out for a refrigerator technician to help you out and add gas to it.
Mar 06, 2010 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Water dripping inside refrigerator under crispers, but
I have a Whirlpool Designer Style 25.1 cubic ft. refrigerator and it looks like we will have to get a new one. There doesn't seem to be any way to get to the hose to unclog it. Thanks.
Jul 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
We just bought this house and the fridge that came with the house is a whirlpool designer style. The problem we are having is that it's leaking water all over inside the fridge and it's coming from the...
This is a common problem with old top mount refrigerators. The foam between the the two cavities starts to break down and sweat due to the differences in temperature between the two cavities. You can try emptying the unit, turning it off for a couple of days and leaving the doors open giving it a chance to dry out, if the condition returns after a short amount of time, then it is time for a new refrigerator, there is no cure for the breaking down of the Styrofoam inside the unit
Jun 16, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
221 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
