Question about Coleman Heating & Cooling
HOW TO INSALL A COLEMAN HEATPUMP DEFROST BOARD
    Champion:
  • 254 Answers
This is actually a very easy task as long as you get a direct replacment board. If not the key essentials are the reversing valve contacts and the power contacts coming to the board.
As long as the board is a direct replacement you can switch wire to wire form the old board to the new board.
Please re comment me if you have any other questions.
Posted on Aug 28, 2008
We replaced fan motor on heil heat pump , now the defrost isn't kicking in, is this a wiring problem or unrelated to us replacing the fan motor?
Check low voltage at heatpump need 24voltsat R and C tterminal s if you have 24 volts on defrost board change board .if you dont have 24volts from r and c you have to go to indoor unit and look at low voltage wireing . Check wire nuts or when replace ing motor might have knock some loose check all low voltage. Hope this helps
Feb 27, 2015 | Heating & Cooling
HI-i have a coleman heat pump- on defrost it gives cold air- not normal. thanks
Do you have electric heat strips for auxillary or backup heat? When the heatpump goes into defrost, the electric heat strips or whatever your source of auxillary heat is, should come on to keep you from feeling the cold air. When the heat pump is in defrost it is essentially operating in the A/C mode, that is why you will feel cold air if the auxillary heat isn't working. You need find out why the auxillary heat isn't coming on if it isn't. It could be do to a bad seqencer or a burnt out element.
Mar 11, 2011 | Heating & Cooling
Is it normal for the outdoor unit on my coleman h/p to make a surging humming noise? the fan does not run during this period, approx. temp. is 28 degrees F. the fan runs 30 seconds befor the unit...
Sounds like your unit is going into defrost mode. When this happens the fan in the outdoor unit shuts off so you get more heat in the outdoor unit to defrost the coils. The heatpump is basically in A/C mode during defrost and the electric heat strips will kick in so you don't feel a cold blast of air in the house.
Jan 03, 2011 | Heating & Cooling
Where is the capacitor located on a coleman heatpump
If you're talking about the outside fan, look where the wire goes into the outside unit. The capacitor will be somewhere near the circuit board and will be round or oval and metal or plastic. If you're talking about the inside unit it will be with the electrical control in the air handler. Write down where the wires go. The terminals on the capacitor will be marked and for the outside unit you will either have 1 that runs both the fan and compressor or a seperate one for each. If you have 1 that runs both the wires must be reconnected to the right terminals. They will be marked COM, FAN, HERM(stands for compressor). Take the old one with you to get a new one. Let me know what you find.
May 04, 2010 | Coleman Heating & Cooling
I have ruud heatpump and it is covered in ice and it does not seem to be defrosting what could this be?
The defrost sensor attached to the outside coil is defective and or the defrost control board in the outside unit is defective.
To defrost the unit,turn the thermostat to cool and lower the temperature as low as it will go. Run in the cool mode until the coils defrost. Then return to heat mode.
Jan 16, 2010 | Ruud Heating & Cooling
Defrost cycles needlessly for extended time period
Without knowing what the problem was with the old board, you're not going to be able to figure much out, I don't think.
Did you check that temperature sensor I mentioned? You will have to pull the top off to get access to it. Normally found connected to one of the tubes for the coil, silver in color, with 2 wires connected to it, near the bottom of the base of the unit.
Dec 13, 2009 | Heating & Cooling
Electrolux Kelvinator - Unit on defrost
When a heatpump goies into defrost, the unit is in a/c mode. and cool air is inside. You may have a bad reversing valve or bad defrost board.
Sep 25, 2009 | Electrolux E23CS75SS Air Conditioner
Heatpump defrost board
REPLACE THE BOARD IS BAD ALSO CHECK FOR 24 VOLTS FROM COMMON AND RED TO MAKE SURE THE BOARD HAS 24 VOLTS.
Jul 01, 2009 | Icm 302c 302 Heat Pump Defrost Timer...
Outside fan runs all the time
Fan wired wrong to contactor. defrost board bad if it is a heatpump. outside fan relay is on board. Rusty
May 30, 2009 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
