Slimview 527 monitor packard bell,missing female power supply from back of set
Open SKy
  • 620 Answers
SOURCE: factory setting on Packard Bell Easy Note F5275 (Model MIT-TIT_N)
Khalil Askar
happy Holidays
Well, it is always better to restore your hard drive if you got the CDs, don't waiste time on tools , that only lead to another problems.
happy nice time
Posted on Dec 19, 2007
  • 123 Answers
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
  • 2692 Answers
SOURCE: Cant use old packard bell speakers
No . The reason that you cannot is that they are amplified type speakers and the amplifier section appears, based upon what you stated, to be in the old monitor.                      Sorry.
Posted on Feb 15, 2009
  • 778 Answers
SOURCE: I recently connected a Packard Bell 1020 monitor
You need a driver for your Compaq's audio card. You can input the exact model number at the site linked below to retrieve the one you need.
Posted on Apr 19, 2009
  • 239 Answers
SOURCE: pc shutdown keeps tripping power supply
The problem sounds like you have a faulty power supply or one of the Boards are not seated correctly.
Posted on Aug 15, 2009
Packard Bell OneTwo M3700 PC boots up but no display
most of the time on older monitors you can set the refresh rate in safe mode and that will, most of the time, resolve the problem otherwise time to purchase a newer monitor.
Jun 26, 2015 | Packard Bell Computers & Internet
Newer monitor won't work with packard Bell R450
Wow, it's about time to dump the Packard Bell. Maybe the Video Card has gone bad in the Packard Bell and if you fix it your old monitor might work.
Apr 24, 2012 | Packard Bell Computers & Internet
My power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
Apr 23, 2010 | Packard Bell (190169) Power Supply
Packard bell ipro yellow flashing light
Huh! Sounds like a power issue. Unplug, try cleaning out the guts in case something got in there, and retry, and again with a spare power supply if things are still bad. It would help to know whether something other than the power supply's clicking, I suppose....
Feb 13, 2010 | Computers & Internet
My packard bell viseo monitor makes my pic's to wide
This issue is caused by missing drivers. You may need to install the drivers (Video card drivers and the Display drivers), the setup will set the adequate resolution for the display so the images will be displayed correctly.
Oct 05, 2009 | Packard Bell Computers & Internet
AC / DC power adapter for Packard Bell SLIMVIEW
Here is the replacement from an UK seller.
Part number is 6860870000 , put this number in google to get the part in your area.
Aug 27, 2009 | Computers & Internet
Bestec power supply
first check for a fuse just after the line input - replace if blown - check your voltage options a plug you set for 240 or 120 volt operation.
Dec 13, 2007 | Packard Bell 200W ATX Power Supply...
Packard bell imedia 1308 power supply unit
Do you have the correct/original power supply, and it is having problems of some sort? If so, you might be able to do some repairs. A common problem is often one or more of the electrolytic capacitors is bad. Take the cover off, and look for bulged capacitors (top of the capacitor pushed up & out). If you find one or more of these, replacement may return the p/s to working order.
Please note in ATX power supplies, you have a standby and full power or main section. The standby portion powers just a small section of the motherboard to sense when the power button is pushed, and activate the main full power section. Obviously, the main section powers the full motherboard, drives, fans, etc.
I've seen several units where the standby section has one or more bad capacitors which will produce either a dead or slow to turn on computer.
Use a voltmeter and monitor the voltages. There are sites on the 'net with pinouts
Check here for further instructions
As regards replacement capacitors: I use mostly the Panasonic FC series available from Digi-Key Electronics. Mouser Electronics also has suitable units. You want capacitors designed for switching power supplies.
Hope this helps you out.
Nov 18, 2007 | Work Station 250W ATX POWER SUPPLY (=...
RE: "Packard-Bell speaker power requirements"
I have a power source that cam with similar speakers that is labeled Packard Bell Plug In Class 2 Power supply Model @ 012-10-1000-07 Input: 120VAC 60 hz 25W Output 9VDC 1A BPCS #:  146139 Maybe this will help
Aug 12, 2007 | Packard Bell (160248-01) Computer Speakers
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
