Question about LG LSC26905TT Side by Side Refrigerator
Where is the water filter
I am looking for the water filter replacement location in the frig. The water taste terrible... Just bought it..
  • matildabeard Sep 07, 2008
    Thanks- found the fitter, but mine is under the light, can't even see it when you pop off the light to replace it. It is a new frig, but the water still taste awful.
  • Anonymous Mar 15, 2014
    cannot locate water filter in the frig.
    Genius:
  • LG Master
  • 1,342 Answers
Is this a used refrig? If new then you should have a brand new filter. For my LG side-by-side the filter is in the top right corner on the frig side. 1/4 twist and it pulls out. But they are $$$$, I found a 3 pack online cheaper than local
Posted on Sep 06, 2008
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
I installed a new PureSource2 filter a month ago. The taste of my water improved and all was fine. Last week a chemical taste began to build and then it became undrinkable. I bought a new filter and...
Search for "how to remove ammonia from tap water" and also for "ammonia added to drinking water". You''l find information, about Chlorine, Chloramines, and Ammonia as different ways to treat water. There is suggestion for ammonia which was to let some water sit for a while to try to off-gas the ammonia. I'd use a glass pan to avoid any metal contamination/confusion for the before/after smell tests. There are kits to test the water.
But first line some facts up
1. Get a water report from the water company to see what naturally occurring minerals are in the source of water and how much of that is removed and what is used to remove it, and, how it compares with local and national standards.
2. Use the water kits, if need be, to confirm these reports.
3. Look at the water filter labels or go to the product's website. There are different levels of purification some these water filters provide. Prices go up correspondingly. I would be surprised if a filter "added" taste. Removing some contaminates might reveal other masked tastes. These filters also recommend the number of hours to be used; the ones with higher removal capability have shorter hours. I'd expect 1-2 years of use.
4. Other solutions:
- use the bypass cap that came with your frig in place of a filter for a before and after taste test.
- use a Brita pitcher.
- look into using a whole house cartridge based system (not water softeners) to get good smelling water everywhere. Replace cartridge(s) annually. Note: I would bypass the outside water bibs for lawn and pool; why use pure water to water the lawn?
Hope this helps.
Ultimately your water source is the problem source.
Mar 14, 2017 | Frigidaire Refrigerators
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Water (not ice) tastes bad in our <3 yr old side by side Whirlpool frig. We've replaced filter, no change. After we empty about 3-4 cupfuls of water, then it tastes okay again.
Look behind the crisper in the fridge and see if it's molded inside the water reservoir. If it is you may be able to put some bleach in it to kill the mold and then run lots of water thru it to clean it out.
Oct 23, 2009 | KitchenAid Superba Architect KSCS25INSS...
My ice taste like plastic
if there is a filter change it or use more of the water so it does not sit too long and get stale
Aug 03, 2009 | GE GSS20IEP Side by Side Refrigerator
The external filter was replaced, and water tastes
Check to see if the filter is in backwards. Try purging it too. Just keep running the water for a couple of minutes to see if the taste improves. If it doesn't and the filter isn't on backwards then get a new filter, that one is bad.
Jul 09, 2009 | Whirlpool GC5SHEXNS Side by Side...
Water and ice has a funny taste
THANKS FOR YOU QUERY JACK.FIRSTLY DEPENDING ON HOW OLD THE APPLIANCES IS MOST MANUFACTURES USE THE SAME OR SIMALAR WATER FILTER SO THAT WILL BE YOUR BEST BET TO CHECK WITH THEM.NORMALY WEN THE ICE AND WATER TASTE FUNNY I HAVE FOUND THAT IT IS WHAT WE CALL ICE BURN AND THAT IS NORMALY WHEN THE ICE HAS GONE STALE OR IS STANDING FOR A LONG TIME TO SOLVE THAT IT IS BEST THAT YOU USE THE ICE UP AS SOON AS POSSIBLE.HOPE THAT THIS SOLVES YOUR PROBLEM.
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Bad water & ice cube taste
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
Mar 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water Tastes Bad
You do not say what type of hose or pipework in supplying water to the unit, if you have a washing machine style hose supplying the water then that is most likely the fault,replace with a copper of clear plastic type pipe, this is avaialbel from your local maytag, amana or admiral stockest you could also try fitting an in line water filter, it is not practicle or possible to replace all the water system components. Regards Advisor
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
212 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
