Question about SanDisk Sansa e250 MP3 Player
Frozen sansa e250 MP3
i've tried every option recommended for my MP3, which has been working well for the last 12 months till last week, when it froze when i turned it on, and now shows that i have no songs/photos, and basically just freeze after i turn it on, press the menu button which shows up music but am not able to select or move beyond this step. I have tried going to the recovery mode and downloading recovery tool but when i try to run it, it just keeps installing it but not run for some reason. I am not able to charge it at all with either the computer or power socket. Please help!!!
frustrated
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Sep 08, 2008
I got a sandisk sansa e250 and the screen is frozen in record
Having received no response in over a month, I assume this is no longer a problem.
Aug 09, 2010 | SanDisk Sansa e250 MP3 Player
How do I reset my Sansa e250?
For resetting Sansa e250 to factory settings:
Start from Main Menu.
Next select:
Settings (image of an equalizer)
Reset All
Yes
Having problems reading the language first choose yours, select:
Language is the 5th option after Settings
Change the language to the language you prefer
Jun 20, 2010 | SanDisk Sansa e250 MP3 Player
Sansa mp3 screen has frozen up
try reseting it. hold down the power button for15-20 seconds and release
Jan 18, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 keeps saying "SYNCHRONIZE TO CONTINUE YOUR MUSIC SUBSCRIPTION"
Here's the deal with WMA files - once your subscription expires (or really,  the license on the WMA file expires) - you will have to renew your music service subscription or the song will no longer play on your device.
Use Mp3 format songs - they'll never give you this problem.
Aug 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
I have a proplem with my sansa e250 after upgrading it. Now I can't start my sansa. The whole sansa is frozen. Just appear SanDisk logo on the screen, blue wheel lite and that's all.
I tryed several time to reset it by pressing the power on (menu) buton for more than 15 sec. It power of after that, but when I try to start it again problem persist - sansa e250 is frozen after logo of sandisk apear on the screen.
Please help me
Aug 17, 2008 | SanDisk Sansa m250 MP3 Player
Will eventually lose songs downloaded?
Okay, here's what i've encountered:  songs that I downloaded on rhapsody, without purchasing, only lasted about 7-10 days unless i reconnected.  once my trial period ended, i lost all the songs.  songs that i've purchased i've had no trouble (although if you load them to the sansa immediately after download, you may get the same message.  its best to wait at least 24 hours).  good luck
Oct 20, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is not turning on and charging.
i had the same problem.  the solution i used was to unscrew the back and pop the battery out and put it back in.  the only other option is to wait for the battery to die, which can take a while.  it's definitely a flaw with the sansa.  its happened twice within 6 months...  good luck
Sansa is acting weird....
Well, you need to return it for a new one. If it has happened in so many few weeks, you need to. It sounds like you may have downloaded a virus. you are going to reboot it and or restart it, you have tried this so it sounds like it is just messed up. exchange it or send it in to get it reset. It will run you about $35. Thanks, Connie
Jun 24, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
