USB Drive not reconised error message on Lexmark X646e
I have successfully scanned items to my usb drive, but several other usb drives I have give an error message saying that they are not recognised. Any solution or pattern as to why some work and some don't.
  • 185 Answers
Some usb drives in ur pc may be older version,so it does not detects the few usb devices u need to unpug and try again most of the time it will detects the device after 3 times.u still have the problem u just replace the drive with latest version.
kindly vote for my rating
Posted on Aug 26, 2008
Usb device not reconised
This message is usually shown when the flash drive is burnt. Try to see if it presents the same message in different computers. if it does, unfortunately it is damaged beyond repair.
If it is recognized as a drive, but it is asked to format the flash drive, try formatting it and see if you can copy and delete files from it. If you cannot, it is really burnt.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
Nov 08, 2013 | SanDisk Cruzer Blade Usb Flash Drive 8 Gb...
Buffalo HD-LBU2 not reconised by computer
Try a drive dock on the Removed Hard drive. The usual problem is the enclosure.
Apr 12, 2013 | Buffalo Technology DriveStation HD-HC500U2...
Cannot transfer files from usb to hard drive but ok other way
Since you did not mentioned how many files or how big is the files you are transferring I will just assume you are transferring several files or several folders. You best shot is to transfer files by batch or transfer it little by little. This way you will know which of the files are not transferring to your hard drive. Please note get all the files that are not giving errors. After doing that you need to scan your USB for errors.
If your Operating system is WINDOW 7 / windows xp
- Go to my computer
- Right click the USB drive then properties
- Click Tool tab
- Then Click check now
- After that try copying the files again.
Sep 10, 2011 | Computers & Internet
NOT RECONISING THE PEN DRIVE-Verbatim ® Store
try a usb port on the back of the computer, if not the drive could be faulty
Jan 03, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
Printer error 70
Brother DCP-165C inkjet All-in-One Printer Error Messages
Once you are familiar with the types of errors that can occur while you are using PhotoCapture Center, you can easily identify and troubleshoot any problems.brother-dcp-165c.jpg
Hub is Unusable.
This message will appear if a Hub or USB Flash memory drive with a Hub has been put into the USB direct interface.
Media Error
This message will appear if you put in a memory card that is either bad or not
formatted, or when there is a problem with the media drive. To clear this error, take out the memory card.
No File
This message will appear if you try to access a memory card or USB Flash memory drive in the drive (slot) that does not contain a .JPG file.
Out of Memory
This message will appear if you are working with images that are too large for the machine's memory.
This message will also appear when a memory card or USB Flash memory drive you are using does not have enough available space to scan the documents.
Media is Full.
This message will appear if you are trying to save more than 999 files in a memory card or USB Flash memory drive.
Unusable Device
This message will appear if a USB device or USB Flash memory drive that is not supported has been connected to the USB direct interface (For more information, visit us at http://solutions.brother.com.). This
message can also appear if you connect a broken device to the USB direct interface
Nov 03, 2010 | Brother DCP 165C Compact Color Inkjet...
ENABLE USB DRIVE
To enable the USB port on the front panel, go to Menu > Settings > Security > Function access > enable flash drive and flash drive print. Thanks
Aug 26, 2010 | Lexmark X646e All-In-One Laser Printer
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
I have several folders on the drive. Can't open
Scan the drive for errors and perform a defrag on it if you get the same error let me know.
Jan 29, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
87 people viewed this question
k24674
jasbo
jasbo
