Question about Canon ImageClass D880 Copier
Where is the on/off switch?
Our fax line was out for a day & later repaired by AT&T, now when we plug the copier in, it seems to be 'dead'. Power is getting to it, but where's the 'ON' Switch?
I called the Canon support line & found out that there is NO on/off switch. She had me disconnect both the phone & power cord then reconnect & then all power was restored.
Posted on Aug 27, 2008
When I plug the telephone line into the Fax machine the telephone line goes dead
Verify that telephone cord from the wall is plugged into fax port labeled LINE. The port labeled PHONE is for a spare telephone set.
Dec 18, 2012 | HP Photosmart C6150 Wireless All-in-one...
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
When I plug my fax into the phone line, my phone line goes dead to all other phones. Never had this happen before. Help
make sure the fax machine slot is not short .remove all the parale line connection and just conncet the fax in to line and check you are gettting the dial tone.
Jan 14, 2010 | Brother MFC 1950MC Printer
Can not receive or send fax. When I send a fax, it says no answer, when I try to receive a fax, the other side hear it was ringing on and on, but they did not get the receiving signal.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq22
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
My Canon MX700 won't turn on.
My Cannon MX700 just died the same way! It was plugged into a high-quality power-strip so I know that it did not get a bad electrical charge. All I know if that I got Verizon Fios a few days before the printer died (including the fax line that runs to the printer) so possibibly somehow an electrical charge came through the fax line and destroyed the machine?
Apr 11, 2009 | Canon MX700 Office All-In-One InkJet...
Connecting fax to phone line kills my house phones
Fax machines are analog devices. It sounds like you have a DSL phone line.
Mar 02, 2009 | HP PSC 2510 All-In-One InkJet Printer
HP 640 fax
Are you plugged into the LINE port?
Oct 30, 2008 | HP 640 Inkjet Fax Machine
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Had a power outage, a day later i noticed fax would not copy or print out internal reports. Faxes received are unreadable. When I try to make 8 or so copies, it scans them but memory stays at 00% and it...
It seems that your fax machine has been damaged by a power "spike" You may or may not be able to get it to work again. You can try to re sequence the machine, by switching off, then removing both the power cord and the telephone cord from the wall. Wait 30 secs or so, then plug in the power cord and switch on. After the machine shows the "ready" mode in the display, then plug in the telephone cord. If this does not work, your machine is toast. Make sure in future to use a line conditioner for both the power and the telephone lines.
Jun 09, 2008 | Brother IntelliFAX 2800 Laser Fax
Canon LaserCLASS Fax 710
replace the line going into the jack, also try unpluging the power cord and plug it back in.
Feb 04, 2008 | Canon LaserCLASS Fax 710 Printer
Canon ImageClass D880 Copier Logo
46 people viewed this question
old marine
old marine
