Question about CMB T43 750 Notebook
Pc screen does not recieve any signal from desktop?????
My screen does not recieve signal is there a way i can send the signal to my laptop and use the laptop screen as my desktop screen
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    No. At least not without configuration and installation of services or programs that make that happen. Doing that blind would be very difficult. Do you happen to have a spare video card lying around? Are you using the onboard video? Does the screen show the initial Power On Self Test info, and then go blank, or does it just not do anything at all? Is there a light on the monitor, if so, does it indicate that the monitor is powered on? If yes, then can you feel static on the screen (if it's a CRT.) A little more info, and I can help you diagnose the problem.
No signal monitor F-417
screen has been identified and installed but you need to send laptop signal to this second screen
there will be a key on the keboard or you can right click the desktop then proceed to send signal to the attached second display
Nov 26, 2013 | Neovo Computers & Internet
My router isnt sending signal to my printer
The router doesn't send signals to a printer. The Linksys transmits a radio signal recieved by the wireless adapters on other devices, if your printer has wireless compatibility it must be setup on the printer, in the wireless settings. I don't think it's a Linksys issue. It a computer software issue. If you post the Computer Make, Model, and your OS, the Printer Make, mode,l I will try to help you. Is this the first time using the Printer?
Jan 11, 2013 | Linksys Wireless-G WRT54G Router
I couldnot find my bluetooth device on my laptop i have succesfully installed bluetooth driver but when i open the my bluetooth places it is asking bluetooth device not found
if it is like my Aspire7110..it is compatible with bluetooth...but has no reciever or transmitter...it only has the capability handling software drivers to accomodate functioning with bluetooth..you may need to either add a peripheral USB device to send and recieve bluetooth signal...or do a search of internal hardware and enable the hardware that allows it to function... ...let me caution you though on using multiple types radio signals for sending and recieving DATA. at the same time....it seems to carry the possibility of confusing WI_FI signals and other wireless instruments that you may be utilizing...so it may be a good idea to disable your wireless during the time that you are utilizing bluetooth..(just a suggestion)...
enjoy your bluetooth experience..lol
todd
Nov 21, 2010 | Acer Aspire One PC Notebook
Laptop to TV Connection
Check if you are sending the signal to the external monitor. On my laptop with Windows 7, I can right click on an open section of the desktop and choose Graphics Properties. In this window, I can choose to send the display to the laptop's internal monitor, the external monitor or both.
Pressing Crtl-Alt-F1 will force the video onto the external monitor on the fly (Crtl-Alt-F3 goes back to the laptop's screen).
When I have added a second monitor to a desktop, I needed to reboot and allow new hardware to be found before the related Screen Resolution (right click on the desktop again) let me find the second monitor and choose if this was a duplicate or extended screen.
I hope this helps.
Mar 08, 2010 | Dell Inspiron 6400 Notebook
No signal to monitor
Hi, Have u tried removing the RAM and CMOS battery and then again put it.
Jan 25, 2010 | eMachines T6534 PC Desktop
Light stays on
Hi
Power options on a laptop often send the computer into stand-by or sleep. Choose advanced power options and set each as desire.
These options can be found in control panel.
Apr 07, 2009 | Sony VAIO PCV-RX260DS PC Desktop
In outlook the send/recieve popup
Make sure that the "Don't show dialog box during Send/Receive" option is checked on the Send/Receive dialog box".
Aug 19, 2008 | Dell Dimension 8200 PC Desktop
I am trying to connect an IBM thinkpad 390X to my wireless network. I have loaded my belkin wireless networting utility but there seems to be no available networks. Any ideas?
Either your thinkpad is not sending out the signals or have weak signals to pick up the network. Go over the settings make sure its set up right. See if the thinkpad recieve any signals any at all from any where..
Get back at me
KJ
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
vojvodabudva
Masood Rasool
Level 1 Expert
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
