I am trying to seend a fax oversea and the diagnostic of the transmision I get It is that the remote modem is incompatible . What does that mean?
    Genius:
  • 2,120 Answers
It's probably a very old Class 2 fax machine or computer. Your fax machine is a Class 3.
Posted on Sep 01, 2008
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
I HAVE TRIED TO FAX BUT I KEEP GETTING ERROR 344 THE FIRST PAGE GO THROUGH AND THEN IT TELLS ME FAX FAILED I'VE TRIED 5 TIMES THE RECIPIENT SAY THE FAX IS READY TO RECIEVE
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted or:
The remote user has pressed the Stop key while the reception was in progress or:
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the fax session was using error correction, disable ECM if not already.
Mar 24, 2011 | HP Office Equipment & Supplies
We have an error meassge 44 when faxing using the Panasonic Laser KX-FL541 to someone else. Can you please tell us what this means? Thank you so much,.
COMMUNICATION ERROR
(Code: 43, 44)
* A line problem occurred. Connect the
telephone line cord to a different jack and try
again.
* An overseas transmission error occurred. Try
using the overseas mode (feature #23, page
47).
here is the pdf file(manuel)
http://service.us.panasonic.com/OPERMANPDF/KXFL541.PDF
Mar 22, 2011 | Panasonic KX-FL541 Plain Paper Laser Fax
What does NGB0 mean on the activity report?
NG is shortcut for "No Good", indicating a problem. "B0" is the fault code for a communication problem, usually caused by an incompatible setting of communication mode G2 or G4 on the remote machine.
Contact the remote operator and ask he set up his machine for EECM or G3 communication mode, then retry.
Jan 06, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
WHAT DOES FAX ERROR CODE 358 MEAN THANK YOU
Dec 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Hp printer 6313 all in have problem for fax. error number 351
The machine has a ECM (Error Correction)error.
Could be:
  1. The remote machine has failed to respond.
  2. The remote user has oressed the Stop button.
  3. Incompatability between two machines may cause the remote machine to abandon the call.
Try turning off ECM in the Fax Settings Menu.
Nov 24, 2009 | HP FAX 1250 Fax Machine (Black)
Incompleter transmission causes? Result NG?
It means No Good. 5 possibilities:
Receiving machine unplugged
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Jul 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Need to send an overseas fax - how do I get the "+" sign before the fax no?
I don't know what you mean about a "+" sign. There is no sign necessary. For example: You can't do it on a regular telephone call either.
If you're having trouble figuring out the dialing codes, this link may help:
http://www.timeanddate.com/worldclock/dialing.html
May 09, 2009 | Office Equipment & Supplies
Hi, Remote Fax Error being displayed
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
k24674
jasbo
jasbo
