Question about Cameras
Need to purchase extra cctv cameras - Cameras
Go to this website:
http://www.cu1.com
If you cant find what you need on their website then just give them a call and I guarantee they will be able to help you. Very professional company.
Posted on Mar 27, 2009
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Where does a father of a three year old son turn to when the mother of his child is out of control?
i will install complete cctv cameras in your households,businesses,institutions. For an extra Ksh500 i will train your how to ride the smart wheel.
31441499430515vandal-resistant-cctv-dome-ugfzdd22zjr2335uzarn4ezi-3-2.jpg Online Jobs in Kenya
Online Jobs in Kenya Kenyan Jobs Five Sok 5 Sock Fiveso Five Sock 5Sok
Apr 19, 2010 | Alert Home Security
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Cctv camera wire pulled off
a simple web search for "scart socket connections" will find details of what signals each pin of a scart connector carry. however, your problem is knowing what signals the wires from your cctv camera carry. only the camera manufacturer, or a service engineer familiar with it, can tell you that.
Aug 18, 2009 | Home Security
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
