Question about Dishwashers
Bosch Int P dishwasher
New dishweasher supplied with MFI kitchen. Unable to open the door to access the instructions etc.... No MFI instructions on how to deal with a newly delivered appliance.
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
If it's new call service under the warranty!!!!!!!!!!!!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Not expensive!
A&E Factory Service
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
How do I open door of the new 18 Danby dishwasher. This model has no latch under handle.
I assume you have gone through instructions supplied fully. You will have to contact, Danby directly, there should be contact information in the instructions.
Mar 11, 2017 | Danby Dishwashers
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
    Hi -
    I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
    Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
    ** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
    I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
    If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
    Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
    Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
    Regards, BElectric
    Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
    GE GSD3130C02WW, DISHWASHER MOTOR HUMS.
    Im a bosch tech and there is a access that you would need a torc srewdriver open plastic door in the bottom of the dishwasher.
    Feb 24, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
    SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
    If your dishwasher leaks, check these:
    Main tub seal
    Door gasket or seal
    Water-inlet valve
    Hoses
    Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
    The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
    • Lower rack
    • Spray arm
    • Spray arm support
    • Wash/drain impellers
    Then pry the seal out of its housing and replace it.
    Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
    Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
    The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
    Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
    1. A common leaking trouble maker
    2. Another common leaking trouble maker - especially for leaking out of the door area
    3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
    4. Some common pump assembly pictures...
    5. Dishwasher Basics
    7. Dishwasher soap notice
    8. Draining and washing help
    9. Help for storing an appliance
    10. How to remove the access panels
    11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
    12. I moved and lost the tap adaptor for my portable d/w, help!!
    13. Important disclaimer
    14. I would like to try to install my own dishwasher
    15. Loading your dishwasher help
    16. Motor and pump assembly screw and impellor help
    17. My dishes are not as clean as they used to be, what might be wrong?
    18. My dishwasher racks have rusted.
    19. My dishwasher will not fill with water
    20. My dishwasher will not start
    21. My soap dispenser will not open
    22. Sand like deposits inside the glasses and d/w
    23. Some common soap door dispensers breakdowns
    Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
    Bosch slimline dishwasher flooded kitchen
    Your debris filter needs to be cleaned. It is found under the dry bar in the bottom of the tub. It looks like a plastic mesh and you can usually remove it to wash it out if not use an old toothbrush etc... this should help.
    Jan 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
    Bosch dishwasher not 'steaming' plates dry
    first check to make sure you don't have a air dry option.then look at the thermostat then heater.
    Oct 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
    Leaking problem from the door
    hi there,
    dishwasher leaking might be due to either of these causes, check these:
    Main tub seal
    remove the:
    * Lower rack
    *Spray arm
    * Spray arm support
    * Wash/drain impellers
    Then try the seal out of its housing and replace it.
    Door gasket or seal
    Water-inlet valve
    Hoses
    May 03, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
    Dishes are not clean due to insufficient water. Arms are clean, strainer is clean, water supply is OK,some soap is still in opened dispenser
    Disassembled solenoid, found plugged inline strainer (caused by water shut-down in building to replace recirc. pump) Pulled and flushed filter basket, problem solved. Solenoid must be removed to access filter which is in sol. body. I hope this can help anyone who does'nt have a tech manual or flow diagram.
    Mar 29, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
    Cant open the door
    Under the unit you can access the leveling mechanism for the legs. Try adjusting the levelers so the unit is lowered. Do so a little at a time and try to keep the unit leveled from left to right as you lower it. This may take tension off of the latch and help you get the door open.
    Jan 27, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
    Dishwashers Logo
    51 people viewed this question
    Top Dishwashers Experts
