Question about Stoves Kitchen Ranges
Code 1106 keeps coming up on my Stoves Genus single oven. I can't use the central knob either. The temperature is no longer showing 1106 is still showing. It happened a couple of weeks ago and I switched the oven off and on again and it all seemed fine, but this morning the panel showed up as green rather than red.
I called Stoves as the oven has completely given up the ghost!
Posted on Aug 27, 2008
How to calibrate oven?
ovens are pre-calibrated by the thermostat and the resistance in the oven control switch
Apr 25, 2015 | Kenmore Kitchen Ranges
Can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
Apr 10, 2010 | Stoves 720EF Electric Double Oven
Hi I have just got my new Genus m/f oven the multi funcition I am fine with but I find I have no instructions or recipes for the Genus.Can anyone tell me where I can get some. or download some I am in...
As a US consumer, I am not very familiar with Genus ovens, but I think they are manufactured by Glen Dimplex. Their website is or try their phone at 0871 222 2502. They may be able to supply you with additional info for your oven. Hope this helps.
Apr 19, 2009 | Stoves Ovens
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves oven genus 900 error codes
Hi phill6x6...try turning on the oven by the main button, and press and hold button 7 until it beeps. Hope this helps you, and a few others!!
Nov 18, 2008 | Stoves 720EF Electric Double Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Oven comes on and off on it's own.
YOU SAID:::>>>The knob for the oven (thermostat/temperature) is gone. The oven now comes on and off after it is used on its own. When turning it no longer stops where it should be at off or 0 degrees.
I SAID>>>>>thats it JGBC20BEA5WH but based on that model it is a gas unit the oven is >>>>controlled electroniclly<<<<< in the back control panel not sure of what know for a oven stat or knob your are adjusting?? plz help here
Apr 05, 2008 | Ovens
Kitchen Ranges Logo
100 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
