Question about Canon FAXPHONE L80 Laser
Printing Activity Report
The fax machine currently prints a report listing the last 20 transmissions. Is there any way to print more than 20 transmissions, or a particular range of dates? Thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
NO, it only does it up to 20, here is the FREE manual look at
Chapter 10 - Report Settings Menu
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e6acb34012ce93f0a6c1b191aa41892c&q=Canon+L80
Posted on Aug 28, 2008
How to retrieve 1 week ago fax history from brother 2280 fax machine
Printing reports
How to print a report
1 Press Reports.
2 Press ? or ? to select the report you want.
Press Menu/Set.
-OR-
Enter the number of the report you want to print.
For example, press 2 to print the Help List.
Following reports are available
1.Transmission
Prints a Transmission Verification Report for your last transmission.
2.Help List
Prints the Help List so you can see at-a-glance how to quickly program your machine.
3.Quick-Dial
Lists names and numbers stored in the One-Touch and Speed-Dial memory, in numerical order.
4.Fax Journal
Lists information about the last incoming and outgoing faxes. (TX means Transmit.) (RX means Receive.)
5.User Settings
Lists your settings.
6.Network Config (MFC-7225N only)
Lists your Network settings.
Jun 11, 2011 | Office Equipment & Supplies
Intellifax 770 print transmission verification report for multipl
You can print an activity report by pressing FUNCTION, 7, 2, START. That will give you the last 30 faxes sent and received, It will only show that you dialed though, it will not be a true verification report. In case you need it, you can download the manual for your fax here:
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
Dec 05, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How do we get an activity report on our uxp 400 fax machine
Printing a list
1 Press these keys:
FUNCTION
The display will show: LISTING MODE
START/MEMORY
2 Press the # key or the * key until the desired list appears in the
display.
or
3 Press the START/MEMORY key.
Activity Report
This report shows information on your most recently performed send
and receive operations (a combined maximum of 30 operations can
appear). The report is divided into two parts: the TRANSMISSIONS
ACTIVITY REPORT, which shows information on transmissions, and
the RECEPTIONS ACTIVITY REPORT, which shows information
on receptions.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
I faxed something last week and lost the transmisson verification report, can it be re-printed? does my fax keep it in memory?
It's possible to print a Fax Activity report which would show both incoming and outgoing fax activity. To do this, do the following:
  1. Press Reports
  2. Use arrow keys < > to select 3. Fax Activity
  3. Press Set
If Fax Activity hasn't been set up, do the following:
Setting the Fax Activity Report Interval
You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF, you can print the report by following the Steps in the next page.
  1. Press Menu, 2, 4, 2.
  2. Press or to choose an interval,
    and then press Set.
    (If you choose 7 days, the LCD prompts you to choose a day at which to begin
    the 7-day countdown.)
I hope this enables you to recover your transmission report. Please post back with any questions or just to rate the solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
How do I print an Activity Report for faxes sent on the Canon Pixma MX310?
Hi ...
The fax machine prints an activity report automatically after every 20 transactions. To print a report manually, follow these instructions:
1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select [ACTIVITY REPORT], then press <OK>. The ACTIVITY REPORT is printed.
Don't forget to vote if this helps ... Cheers :)
Aug 02, 2009 | Canon PIXMA MX300 All-in-One Printer
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
Print Fax Confirmation
Press MENU button, then 5 on the numbers keypad. you should be able to scroll through a list using the up and down buttons. #1 is the HELP LIST, #2 is AUTO DIAL, #3 is FAX ACTIVITY which shows LAST INCOMING AND OUTGOING faxes,#4 TRANSMISSION,prints a TRANSMISSION VERIFICATION REPORT of the last transmission. #5 USER SETTINGS lists your setting. To select your report, select the REPORT NUMBER, press SET, then START, to print
Jun 23, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Report Printing
Seeing old already printed report is your only hope i'm afraid,
once activity report is printed the memory is reset to allow it to remember next lot of fax's for you.
Oct 25, 2007 | OKIFAX 5400 Plain Paper LED Fax
Canon FAXPHONE L80 Laser Logo
247 people viewed this question
old marine
old marine
