Question about Casio Cassiopeia E-125 Pocket PC
Casio pocket pc calendar doesn't show appointments that were syncronized from outlook: If I sync with outlook, the appointments I add on the Casio E-125 show in outlook, but the ones I add in outlook don't show on the Casio E-125 in regular Calendar program, but they DO appear in the mobile calendar program I prefer the regular Calendar program, but I can't get it to work. Any IDEAS out there? __________________ BK
    Master:
  • 551 Answers
The Menu: VIEW - Categories option at the bottom, has all categories checked off. However, the logic dictates that it will only show the categories checked off, and if any appointment (appointments being made in outlook are not categorized) with no category would not show in the pocket pc. The logic written into the software, is, if no categories are checked off, then it will show ALL appointments. It would be nice if there was an option in the category view menu to SHOW ALL, but there isn't. You just have to uncheck all the categories.
Posted on Sep 05, 2005
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
Active sync problem with calendar for samsung sgh-i780
Hi, how many years further you go? I have no problem up to 5 years...
Mar 08, 2009 | Samsung SGH i780 - Microsoft Windows...
Appts on iPhone do not synch to computer
you need to set your preferences in itunes to sync properly
Nov 17, 2008 | Apple iPhone Smartphone
PIM Appointments 5 hrs off
Verify your time zone in your phone and outlook server. it should match so that the sync happens properly...
Oct 18, 2008 | Samsung SGH-D900 Cellular Phone
Not able to synchronise
did u set the pc-sync up to use the correct com port? got menu, then, casio, then, transmission setup and configure correct serial port.
Feb 04, 2008 | Casio Pocket Viewer PV-S400 Plus Handheld
Sync problem w/outlook contact
I use my 548 to keep my work and home versions of Outlook syncronised. I have about 70 contacts stored. Three suggestions.. 1) Do you have enough free memory? Emails can take up megabytes, and for that reason I choose not to sync emails. 2) Are all of your contacts in the same Contacts folder? I have two contacts folders on my home Outlook, one for me and one for my wife, I only sync my contacts to my 548. 3) In Activesync, click on Options, Sync options, contacts, settings and make sure that "Syncronize all contacts" is checked
Sep 12, 2005 | HP Jornada 548 Pocket PC
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Unresolved Items when synching
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Sep 08, 2005 | HP iPAQ H2215 Pocket PC
Hx4700 not sync all items in calendar
So make sure that you are displaying all categories.... If while on Calendar screen, you click on Tools, Categories... then all category boxes shown , should NOT be checked. If any of them are checked, then you will only be seeing that category of appointments.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
BE300 and PC Connect
If you have active sync installed it will stop pc sync from operating properly. If you don't have active sync on your system then go to the below forum and do a search for info on syncing. There are issues with pc sync that have been remedied with some updates.
Sep 06, 2005 | Casio Cassiopeia BE-300 Pocket PC
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
127 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Computer Links
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
