Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Jennair dishwasher JDB-5
None of my control panel lights work although the machine still works. When the various cycles are completed the clean light illuminates. The problem is I have no idea what cycle I am choosing.
Any ideas??
  • wontbuyagain Jan 14, 2009
    Having the same problem here. Ours is only 3 mos. old and under warranty still. Told I need a new control panel. Part is on back order though til end of Feb. Maybe Jenn-Air should evaluate this design flaw!
  • 338 Answers
SOURCE: Door doesn't want to open
The handle is broken. You may have to force the door open so you can work on replacing the handle.
Posted on Nov 25, 2008
appldoctom
  • 311 Answers
SOURCE: Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of plastic.no eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard somthing.im afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off ,once.you can do it.ps you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
Posted on Jan 03, 2009
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Posted on May 19, 2009
heatman101
  • 43501 Answers
SOURCE: jennair gas oven. lower burner won't light, i.e.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Jul 18, 2010
  • 7 Answers
SOURCE: same thing happened today
Replace the control panel yourself. Part is about 150. ten years with no probs for this DW must be a record....
Posted on Nov 05, 2010
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Stuck on washing cycle
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
Nov 17, 2014 | Frigidaire Washing Machines
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Jennair gas oven. lower burner won't light, i.e.
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Same thing happened today
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Door doesn't want to open on my Jennair JDB 1080 dishwasher. Gets stuck, like the latch doesn't spring open. What can I do to it?
Nov 24, 2008 | Jenn-Air Dishwashers
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Jennair dishwasher timer stops halfway thru wash cycle.
Try using a cycle that doesn't boost the heat. Usually a quick or china/delicate cycle. Any cycle that heats the water pauses the timer until it is done. Some machines even select this with heated dry. The sensor that controls this can go bad and stop the timer completely. If it operates for the complete cycle , look for the sensor and replace it. There is usually a wiring diagram somewhere in the machine sometimes in an envelope inside the door, control panel or behind the front bottom panel
Jul 04, 2008 | Dishwashers
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
1,105 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
