Question about Epson PictureMate (C11C556001) InkJet Photo Printer
Non-Epson cartridge Hi, I have an Epson picture mate and, until about six months ago was able to print from this using cheaper cartridges not manufactured by Epson. I recently went backpacking around the world and have returned with lots of photos - only to find that my printer will now only print from official Epson cartridges (I still have 4 full cartridges left!). Can you help me to resovle this problem please? Thanks
  • larrylaf Oct 09, 2008
    I purchased Epson Pcturemate T5570 compatible ink cartridge from inksell.com. Printergets stuck saying "Printing..." and the 4x6 sheet of paper is halfway in the printer. I can print a nozzle test page just fine,
  • Geeta Burgan Feb 16, 2009
    I have the same problem could you please email me at gburgan@ntlworld.com with a solution. I would be very grateful.
  • 102 Answers
Yes this is a common problem. Go to Epsons web site and download any updates and this will usaully fix it. If not reinstall your printer and then again check for updates.
Posted on Nov 01, 2008
Changed cartridge, received a code "P", says to install a new cartridge, but I just did install. Will not allow to do a clean print head.
hi, first turn the printer off and unplug it and let set for 30 mins. Ig that doesn't work try taking the cartridge out and reaching inside where you put the cartridges go and clean the print head with alcohol with a q-tip.
Nov 22, 2015 | Epson Picturemate Picture Mate Deluxe 500...
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
Mar 21, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Have not used my epson cx7400 printer in months and the printer head is probably clogged up. Tried installing ink but did not fix problem
Here is a Link that would help you. You can also download the manual if you need. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQs&oid=89902&prodoid=63069503&category=Products If you find this helpful, pls rate me. How long should an ink cartridge remain in the printer? When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head. I know you said you changed the ink, but you must use Genuine Epson Cartridges. Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can MAKE YOU & keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it. Gets costly.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 23, 2010 | Epson Office Equipment & Supplies
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
My printer will not recognise non epson cartridges
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!! How you were able to use generic is amazing. I was not able to do that!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
TRYING PURCHASING GENUINE, and see what happens? This is the only advice I can give you. If you find this helpful, pls rate me.
Oct 27, 2009 | Epson Printer
Non recognition of genuine Epson cartridge which was already used
try this hold down all 3 bottons for 20 sec this will reset your printer
DONT FORGET TO RATE
Nov 24, 2008 | Epson Stylus Photo R220 InkJet Printer
Unused printer
Hi, the print heads are clogged up usually caused by leaving a ink cartridge in the printer when not using it, ie over time, but epson have this problem alot.
you could try this http://www.supermediastore.com/cleaning-cartridge.html
ie if head cleaning dont work,,
this should fix it, otherwise its $48 + vat was the cheapest i found for new print heads or £75 for epson to fix it.
i would replace printer ie if cartridge dont work,,
Happy New Year
John
Dec 14, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
209 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
