Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
3-D Effect How can I fix the colors to align them right? I've tried going to menu but still can't find it. Thanks, Jessica
  • 1,030 Answers
When you go into customer menu is there and option intilted 'CONVERGENCE' if not this is a indication of a blown special fuse called fl231. there should be three options in this autoconvergence red convegence and blue convergence see if anything happens on these it may need a service convergence
Posted on Aug 30, 2008
My Lexmark printer X2690 will not align properly after I' ve installed a new colour cartridge I have taken the security strip off! please help
You could try to remove and reinstall your color cartridge again.Do a Clean Cartridges cycle.Then do an Align Cartridges cycle.
Oct 26, 2011 | Lexmark X2690 All-In-One InkJet Printer
The far right hand side of pages printed on my HP Color LaserJet 3800n are faded .. as though the toner is not distributed evenly .. I've tried shaking the black cartridge but this has no effect .. can...
From the control panel, go to diagnostics menu and then select PQ pages. This will print color diagnostics pages so that you can see if it is one color or all colors that have a problem. If one color then it is either the cartridge or the scanner. If it is all colors then it might be the high voltage board, or possibly one bad cartridge causing a voltage drop. If you recently changed a cartridge put the old one back in and try a test print.
May 17, 2011 | HP LaserJet 3800n Printer
Check the following steps :
Double-click the HP printer icon in the system tray at the lower right end of your desktop. Navigate to the "Toolbox" tab.
Click on the "Status" link on the left side of the window. Scroll through the "Status" menu and click on the "Print Info Pages" link.
Click the blue "Print" button located to the right of the "Configuration Page" heading. Check the print page to see if the "L" shaped bars are overlapping or bleed into each other.
Contact HP directly for a repair or replacement if the "L" bars do not have any overlap, as that will indicate an extensive mechanical problem that can't be fixed through troubleshooting.
Return to the "Toolbax" tab if the color bars are overlapping. Click on the model number of your HP color laser printer at the upper left end of the window. Click on the "Device Settings" link.
Choose the "Print Quality" option and then click on the "Calibrate" button on the right side of the window. Click "OK" in the new window that appears and wait for the alignment calibration process to finish.
Attempt to print a document again and see if the alignment is still off. If the alignment is not correct, repeat the calibrating, since the HP color laser printer may need to be calibrated more than once to fix the alignment.
Oct 27, 2010 | HP LaserJet 4600 Printer
3D effect where the blue color is a little lower than the rest of the colors. More noticeable on words.
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from
May 20, 2010 | Philips 51PW9363 51" Rear Projection...
My picture is completely distorted i tried to align colors on the menu and no good.Can it be my projection lamp? How much is the avg price? Is it easily self installed?
Not lamp,color effect 3D,it the convergence is dead.You know how to solder right?Buy the convergence kit repair what in that kit.Tries these websites Tv Repair or
Sep 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
After replacing the convergence the three colors are still not aligned
there should be a menu button on the tv itself go to picture setting and reset all three colors to the middle. if that doesn't work then you'll need a new regulator for the convergance which is about 25-50 dollars
Oct 22, 2008 | Sony KP-57WS500 57" Rear Projection...
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
Hi there I've noticed youve been really helpful so...
The )( is indicating your loosing High voltage required to pull the raster across the screen. This can be tweaked but a short lived solution. I suggest it may be a good time to start shopping.
Jul 27, 2008 | Proscan PS61670 61" Rear Projection...
Need the codes to enter the service menu
First, you will need to fix the convergence problem by replacing
the convergence IC's,then activate auto focus and last,if necessary, enter the servicer mode................T.
Nov 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Proxima C160 Color Convergence Issue...
There are no adjustments for convergence in the service menu. The code is: Effect, Blank, Video, Computer, Volume Down, Volume Up.
Jun 01, 2007 | ASK Proxima C160 Multimedia Projector
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
