Question about TruTech PLV16320 Television
Coaxial cable hook up
Can't find coaxial cable hook up on this trutech 26 inch LCD monitor. Is this unit a tv, or is it simply a monitor for games and dvd's?
    President:
  • 814 Answers
You have to buy a adaptor for coaxial to television antenna hook-up. One side is used to hook up the cable to and the other side is to hook up to you televisions antenna's screw hook-up. These adaptors can be bought in most electronic stores and you should be able to find them on line. Just use google for cable to television adaptors. I hope this helps you with your problem.
Posted on May 17, 2009
No place to hook up coaxial cable for cable
If you have composite jacks on your tv, you may have to get a modulator that converts coaxial cable to composite cable.
Sep 28, 2013 | Mintek DTV-263 26 in. TV/DVD Combo
Do I need a special cord to record from digital tv
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
Oct 02, 2010 | TruTech TT1620 DVD Recorder
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
I cant find the video input for dvd
It sounds like your unit has no AV jack on it. Therefor the best way to resolve this is to use a cable box or a vcr so the output for the vcr or cable box can be connected to the tvs antennae jack, through the coaxial cable, and the game unit can be connected to the audio video jacks of the vcr or cable box.
Simply switch the vcr or cable box to the line mode to activate the game port.
Apr 29, 2009 | Televison & Video
Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Feb 09, 2009 | Element ELC-HS321 32 in. LCD TV
Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
Jan 28, 2009 | TruTech PVS31170S1W 17 in. LCD Television
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Hot to hook up cable
This monitor with a television tuner does not have a coaxial connection. I was able to get cable by connecting (buying if you don't have) to my dvd/vcr which had the coaxial connectors. Then I ran the video component cable (green, blue & red - had to buy that) from the tv to the dvd/vcr. Then I ran the audio cable (red & white) from the tv to the dvd/vcr. A little tricky figuring out where on the tv to actually connect but eventually got it. YUV2 on the side.
Dec 24, 2008 | TruTech PLV16320 Television
TruTech PLV16260VM 26-inch LCD Monitor
No it doesn't. You must use a set top box.
((cable box))
Jan 02, 2008 | TruTech PLV16320 Television
TruTech PLV16320 Television Logo
361 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
