Question about Dishwashers
Codes Hi, my dishwasher keeps showing me either F7 or F9 when it doesn't want to work. Yet sometimes it works perfectly. Can you please tell me what these codes mean. Thanks
  • 639 Answers
IDEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Not expensive!
A&E Factory Service
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
My dishwasher fisher pykel twin dish washer model # DD 605 , SHOWS AN ERROR CODE f7 first then shows error code f9
The top dishdrawer is hard to open or close as the lid seal actuator motors are most likely faulty or lost power. The scraping is the lid seal touching the drawer lid. The F7 and F9 error are a result of this fault with the actuator motors.
At the base of the dishwasher housing under the bottom drawer is the power board. From there the power is supplied to the controller and the motors. These motors move the lid seal into position. First turn the mains power to dishwasher off and then back on. See if this resets the motor position. If not you will have to call the technician to fix the problem. But if you are technical savy you could go to the base of the dishwasher and take the connectors of drawer 1 out from the power board and swap with drawer 2 which is working.
If power board connection is not making any difference, then motors are the likely problem. Needs a lot of expertise to replace and adjust the motors.
Mar 23, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
LG double oven shows f9 code in both ovens
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Nov 19, 2013 | LG LWD3081ST Electric Double Oven
The mouse seems to be locked
Hi
please take a look at your top row of keys on the keyboard
usually there is one normally the F7 key with a picture of a finger and hand on it
sometimes it is the F9 key
these keys normally enable/disable the mouse/touchpad
try pressing the key leaving a few seconds before it works
and sometimes you have to press FN+F7 for it to work
hope this will help you
many thanks
Jun 19, 2011 | Computers & Internet
How do I adjust the screen brightness?
Press and hold fn button on your keyboard, then press F7 to decrease brightness and F8 to increase brightness. That is Fn + F7 or F8.
If F7 or F8 doesn't work try F6 or F9.
Or you can just start from F1 to F9. One of these buttons certainly would work.
Regards.
Apr 19, 2011 | Compaq Presario Notebook
CAn you please tell me how to switch off the 'mouse' on the computer itself. I know I am supposed to press the "funtion key" and another one in the top two rows, but I am not sure which one. Is it the key...
if im not wrong....its Fn+F7.........
you will find a finger symbol in that key....you need to press Fn and F7 together....it it doesnt works then press F7 alone....
Apr 20, 2010 | Dell Latitude D800 Keyboard
Hi i have f9 coming up can someone help its a mistral
F9: OUTDOOR COIL PIPE TEMP SENSOR FAULT F7, F8, & F9 generally related to improper installation of temp sensors connectors & wiring.
please check the wiring....
and also try short circuiting the terminals at the back of your remote and replacing the batteries
if you find the wiring proper and the above procedures doesnt work... its likely a hardware issue and its recommended you contact the manufacturer....
Aug 10, 2009 | Heating & Cooling
Touch pad dosent work
Hi
I'm not sure please try pressing Fn+F9 (or try Fn+F8 or Fn+F7)
this should enabled/disable the touchpad.You also can enabled/disable it through a pointing device software.
goodluck,takecare.
May 21, 2008 | Acer Computers & Internet
Cleaned stove, replaced bottom element, stove reading F3, F7 and F9. Oven will not work. But will work on Clean Cycle.
Initially, it sounds like a problem with the lock mechanism. Without the brand or model number, it's impossible to know what the fault codes mean. You may find them listed on a tech sheet in a plastic pocket behind the console.
F3 is usually a temperature sensor. F7 may be a keypad problem and F9 (on some machines) means there's something wrong with the door lock.
Sometimes during a self clean cycle, a high temp thermostat/ fuse fails, preventing the door from unlocking.
Mar 09, 2008 | Kitchen Ranges
D3350 - Code F9
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
174 people viewed this question
Top Dishwashers Experts
