How to use jumper settings on FD1158C
The FD1158C dual floppy drive has the problem that both drives are not recognized. One or the other but not both. The jumper settings are suspect, what are they and how are they used?
  • Anonymous Sep 02, 2008
    A jumper diagram would be nice. Anyone got one?
  • 66 Answers
All floppy drives have diff settings though
try this for more info
hope this helps
Posted on Sep 03, 2008
Jumper settings Chinon F354E floppy drive
Hi Robert Bissett,
The amiga drive Chinon F-354 have jumpers, long itme ago I did this.
I think you have to set a jumper for the drive there is both normally marked with DS0 one of the drives need to be changed to DS1.
Dec 23, 2011 | Computers & Internet
What is the use of the jumpers on the floppy drive board?
hi there,
only very old floppy drives used jumpers in case two drives were installed so they could be set as A and B. Nowadays floppy drives are jumperless and are set by automatically according to which cable connector plugs into the drive. That's why floppy drive cables have some twisted wires so they can set drives as A and B in case more then one drive is being used in the same system, which is also rare these days.
Jun 27, 2011 | Computers & Internet
I am installing an EPSON SD_600 5.25 inch flopy drive into a gateway computer. Which if any jumpers do I need to change into order to have this drive share a data ribbon cable with the existing 3.5 inch...
Unless floppy drive cables have changed in the past few years, they're designed for 2 floppy drives, with the jumpers on both set the same way. There's a small twist in the cable that changes the drive addresses instead.
Or you could just replace the existing drive with the new one.
Mar 13, 2011 | NEC Epson Combo 5.25 and 3.5 Floppy Drive...
How do I add two floppy drives, A and B? There are no jumpers to set.
If you're using an IDE cable and a fairly modern motherboard, just plug one IDE into the first drive, the second IDE into the second drive, and then plug in the IDE cable to the motherboard, and it should automatically configure the drives regardless of jumpers.
Mar 05, 2011 | NEC FD1231M 144MB 35" Internal Floppy Disk...
I need a JU-253-403P floppy drive or equivalent
[International Portal Floppy Drive , www.ruanqu.net] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Mar 05, 2009 | Panasonic (JU257A607P) (JU257A607P)...
Adding a hard drive to a PC
You need to set the little jumpers at the rear of the hard drive and the cd rom drive. Set the hard drive as Master and the cd rom as Slave. Both devices should then be recognized.
Dec 30, 2008 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
New ECS G31T-M won't recognize IDE devices
Locate the boot options in your BIOS and set it to boot from the Hard Drive
Oct 13, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
Teac FD-505-318 jumper settings
hi,you need to have a look on the jumper settings on the drive and set 1 to master and 1 to slave
Sep 06, 2008 | Computers & Internet
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
I need to reinstall my driver.
Nov 14, 2007 | Panasonic (r) Ultra-Compact Digital...
Computers & Internet Logo
371 people viewed this question
David Payne
David Payne
