Question about Scanport Computers & Internet
Faulty LCD Monitor ?
For the past 4 days my LCD monitor has been doing something odd.
When I wake the monitor in the morning the whole display is white fuzzy with some patches of blue and red. On one occasion I could just faintly see a corner of the desktop behind the white fuzzy stuff. This does not happen at anyother time. It only happens when I wake the monitor in the morning.
If I shut down the computer and wait a minute and turn the computer back on then the monitor behaves as it should. This morning it took about 5 shut downs before the monitor kicked on. The monitor is about three years old.I
  • prismsand Aug 28, 2008
    Power supply in the monitor? Since I last posted the monitor now "whites" out all the time now. It happens when the monitor goes into sleep mode. I've learned to unplug the monitor from the computer. When I plug it back in it works, at least for awhile.
    Sandra
  • prismsand Aug 29, 2008
    KDS 17" Model #700p. I normally have the monitor plugged into my Dell Xeon tower. I decided to plug it to my laptop. The monitor works fine on the laptop.
    Perhaps it is a video card issue? I've never seen a bad video card behave this way.
    Sandra
    Brigadier General:
  • 5,158 Answers
Off hand it sounds like a power supply issue. sometimes fixable sometimes not.
Robert
Posted on Aug 28, 2008
  • Roberta Smith
    Roberta Smith Aug 28, 2008
    I would probably be able to give you more detailed information if you would provide the brand and model number
    Thanks
Display did not wake back up from sleep; no lights blinking and completely non-responsive, even after reboot. Display seems to have died. Possible adapter failure? I am running this on an '06 Mac Pro...
If you can connect an alternative monitor from a friend the fault of the monitor can be once for all confirmed. Now start from the power section, check for the power supply failure to the mains section of the LCD. If power is faulty and the +Bvoltage is absent , check for the drives, however if the power supplu is OK then a possible fault in the main board is for sure, a failue of the processing IC . you will need help from the service dealer to check up this board to confirm. Good day
Aug 16, 2010 | Apple Studio 17" Flat Panel LCD Monitor
How do i get it from falling asleep> everytime i try to start the monitor sleep sign comes up
Follow the steps below:
Check if allow this device to wake the computer is checked in Device Manager.
1. Click Start, type Device manager in the Start search box and hit Enter.
2. Select keyboard, it will display your keyboard, right click and select ‘Properties’.
3. Select the ‘Power management’ tab.
4. Check the “Allow this device to wake the computer” check box.
5. Repeat these steps for Mouse and Network adapters as well.
Jun 16, 2010 | HP Pavilion F1703 17" LCD Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
Dell Monitor E207WFP Picture Not Centering
Try another monitor on the PC, see if that helps.
If it does, the monitor is faulty. Try resetting it to fctory settings.
If it isn't, it's probably your graphics adapter, or something in between.
First check the vga cable, then reinstall the graphics driver.
I hope this helps,
Yannick.
Jun 17, 2009 | Dell E207WFP LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
Sep 28, 2006 | Samsung 710V 17" LCD Monitor
Computers & Internet Logo
132 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
