Question about XFX Computers & Internet
Blank screen, No video signal
Whenever I turn on my PC I am getting a blank screen. But then after a week or a day it will show video just fine but then I shut the pc and turn it on again and there will be no video. The video will remain on as long as the pc is on and I don't reboot. I tried this with two monitors and got the same thing. The pc turns on just fine. The video card cooling fan is spinning so it is working. This is a new card just installed it about 3 months ago but this started happening about a month ago.
How can I fix this and how can I get the video to come on so that I can make the changes to solve this issue????
Thanks!!
  • 7 more comments
  • elpas007 Aug 26, 2008
    I did in fact uninstall and reinstall the video drivers because while I was having this issue I was reformating my HD and reinstalling everything and right after I reinstaled the drivers and rebooted the screen was blank.
    Anything else I can try??
    Also since I get a blank screen it will be very hard to do anything like uninstall/reinstall drivrts or anything else. Is there anything I can try toget my screen up long enough to try to do a fix or do I have to keep rebooting until the screen come up by itself??
    Thanks!!
    Hey!!
    Marked had some good advice on solving this issue but is was in facted tried and to no avail. Still keep getting the blank screen even though the PC is working fine.
    Here is a list of everything I tried so far. Its been almost a month and I need to get this up and running.
    I tried it with another monitor with the same result.
    The pc turns on fine-all the lights and fans go on.
    Checked the video cooling fan - The card cooling fan is spinning.
    Checked the cables -All the cables are on tight with no breaks, bends or damage.
    Checked the card - The card is firmly in place in the pcie slot.
    Tried to take the card out and putting it back in.
    It has the latest drivers.
    Uninstalled and reinstalled drivers.
    Why does the card sometimes work and sometimes it doesn?t? What can I do to fix this and how can I get the video to appear so I can make the changes necessary to fix this issue??
    If anybody can fix this you will be my hero!!
    Thanks so much!!
    Have not tried the battery. I will try replaceing it but here are some specifics:
    Intel duel core 3.0 GHTZ CPU.
    Asus P5E Deluxe Mother board
    680 Watt power supply
    2 gig DDR Memory
    2 HHD, 1 IDE 200GB and 1 SATA 500 GB
    XFX 8800GT video card
    Also I need to point out that the Motherboard, CPU, Graphics card and Power supply were all installed brand new about 4 months ago so the mother board battery is kind of new and I don't know if this helps but it keeps time really good.
    Since the battery is still fairly new I was wondering if anybody could suggest anything else.
    Thanks!!
    I was suggested that I try to replace the backup batery on the MB but since the MB is fairly new (4 months)and the pc keeps great time I am hoping for some other suggestions. I will try replaceing the battery but here are some specifics which might help find a solution:
    2 gig DDR Memory
    21" high resolution monitor.
    Also I need to point out that the Motherboard, CPU, Graphics card and Power supply were all installed brand new about 4 months ago.
    while I will go out and get a new battery is there anything else I can try??? Thanks!!
  • elpas007 Aug 27, 2008
    Thanks Ohms for your feedback. I did go to the xfxforce.com website to checkout the specs for comparibility and my pc has all the recomended requirements and then some. While I was there I also contacted thier technical support about this issue but they have not gotten back to me as of yet. I also tried to take out the card and put it back in several times but to know avail. I do not have another pc I can test the card in but I would be very curious to see what would happen.
    Any other suggestions you might have would be most welcome.
    Thanks!!
    I got some good feedback from Ohms. Based on what he suggested I did go to the xfxforce.com website to checkout the specs for comparibility and my pc has all the recomended requirements and then some. While I was there I also contacted thier technical support about this issue but they have not gotten back to me as of yet. I also tried to take out the card and put it back in several times but to no avail. I do not have another pc I can test the card in but I would be very curious to see what would happen.
    Any other suggestions anybody might have would be most welcome.
    Thanks!!
  • elpas007 Aug 28, 2008
    I did take out the video card and reseat it firmly in place. Then I went into bios and set the defaults. Then I tried to update the drivers but when I rebooted the screen became blank again. Remember I get nothing on the screen when I reboot. I can't even see the power on self test or any of the boot up process. So I get this problem before any of the drivers are loaded.
    Is there anything esle I can try?
    Mytechguru had some good suggestions. This is what I did:
  • elpas007 Aug 29, 2008
    Thanks for the suggestion!! I just need to know what do you mean by "video adapter"??? Do you mean its the video card that is causeing this?? Please explain.
    Thanks!!
  • 83 Answers
You Have To REmove Your Card (uniunstall)
And Install it Again From The Cd Installation
Posted on Aug 28, 2008
    Genius:
  • 2,035 Answers
First remove the graphic card and connect the monitor cable to video output of the mother board check the symbol of the monitor which at port connect the monitor and check if the video is coming on it , if yes then is the problem with graphic card get it replaced as its still under warranty ......
Good luck...
Posted on Aug 27, 2008
    Master:
  • 623 Answers
  • Check that the monitor is turned on.
  • Most have a light to indicate power and another to indicate that it is receiving a signa;l from the PC.
  • Check that the video cable's connectors are securely and properly fastened to the graphics card and on some models to the monitor.
  • Check that no pins are bent or miossing from the connector.
  • Unplug the PC and make sure the graphics card is securely and properly installed into it's slot.
Posted on Aug 26, 2008
  • 19,396 Answers
First check the cable by moving it to test it influences the siignal.
If cable it is ok, then it is probably a faulty video adapter.
A replacement video adapter starts from $7, you can buy a good video adapter for $30 or so.
If you buy you can ask here how to replace it, it is not a difficult operation.
    Genius:
  • 2,028 Answers
Seems that everyone is taking the video driver approach, since this isn't working, let's try a different approach. I believe that this is going to be a bios or an incompatibility issue. Try the bios download from the link bellow.
http://drivers.softpedia.com/get/BIOS/Asus/Asus-P5E-Deluxe-Bios-0105.shtml
  • Ryan Rogers
    Ryan Rogers Aug 28, 2008
    Yeah, you can try the bios download I posted earlier.
  • Ryan Rogers
    Ryan Rogers Sep 02, 2008
    Have you tried the bios download?
    Master:
  • 521 Answers
Go into safe mode and uninstall graphics
driver then try and load windows.
  • tech expert12 Aug 28, 2008
    as you have tried every solutions and got understood of many things.but calling the technician is a better option to try.as he will be doing it on site.and it would be more beneficial.
    please rate the solution.sir.thanks.
  • 3,051 Answers
Well here is somthiong for you to try ok first i would power down the pc now unplug the power wires to the motherboard from the power supply now press and hold the bowerbutton for 15 seconds to release any esd now if you have not all ready done so remove the card and get a eraser and clean along the edges of the card then make sure that the card is clean and you may want to insert it into a different pci slot and replace the screw dont overtighten it ok now plug in the motherboards wire form the powersupply and plug in the powercord to the pc and turn it on and see what happenes pleasee let me know what is going on ok best regards mike
  • Michael Thomas
    Michael Thomas Aug 27, 2008
    i am still curious is the problem fixed yet or is it still ongoing best regards mike
    Scholar:
  • 93 Answers
You need to update the drivers
  1. Re-seat the Graphic Card
  2. Go to BIOS and Rest the BIOS to defaults
  3. Click here on the support and go to drivers and update the drivers
Regards
http://www.MyTechGuru.us
  • 1,879 Answers
Definite hardware issue (as you don't see nothing on boot).
double-check the compatibility + requirements.
re-seat the video card.
better if u can try it on another computer + observe.
go for warranty.
  • 10,594 Answers
Since you have not mention PC specifications, so I assume, Back-Up battery in PC looks down. Its installed on board, please replace it.
  • Shahid Electronics
    Shahid Electronics Aug 26, 2008
    You right, in 4 months, back-up battery would be fine, no need to replace it. How does PC respond when power up? does it show company logo while booting up?
  • 6,487 Answers
Try to uninstall/reinstall the video card and make sure that you're installing the software from the setup CD and also you can try updating the software of the video card if you still have the problem after uninstalling/reinstalling it..
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 27, 2008
    If this MOBO has a on board video, this is the way way to really check what is causing this prolem, or if yoiu can just try a different video card because if that another video card work fine definitely we already know the problem is with the video card , because it really dont have any thing to do with the battery...
    Good luck........
  • Mark Gil
    Mark Gil Aug 29, 2008
    Yes, this is really cause by the video card and better haev it replace..
    Good luck........
My LG R410 makes wierd whenever i press any buton noises and blank screen
It will do that if the screen is black, Beep repeatedly, every time you tap a button. If that is the only problem you have, you don't have a problem. Just don't push the keys a blank screen. The statement "it was fine then i shooted it down then again i turn it on it was blank" , could you rephrase that statement? Is the machine not booting?
Nov 12, 2012 | Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Dreamcast shows logo then goes blank
Definately the DC. Try ensuring that the connections are properly made first, and if that fails, try wiping the laser lens (very carefully) and the disc with a smooth cloth.
Jul 18, 2009 | Video Game Consoles & Games
LG LCD Monitor L1530S problems
Most screens will show nothing or go to power saving mode until the PC is turned on. The monitors need a signal in order to be 'active'.
From your description it could just as well be a problem with the PC rather than the monitor. The easiest way to find out is to connect another PC or laptop to the screen or connect another monitor to the PC unit.
Did you try pressing the Del key or F2 key when you turn on the unit to get into the Bios?
Jules
Jul 16, 2009 | LG L1530S 15" LCD Monitor
Kworld pc to TV - avi does not show on TV screen
This turned out to be due to weirdness in my laptop's onboard graphics card. If I set the external monitor to display the way an external monitor usually does, as a clone of the laptop screen, the videos show up blank. But if I set it as dual-screen (extend my desktop to this monitor) and drag the video app onto the second monitor, it works fine.
Jan 07, 2009 | KWorld PC to TV (0872880887527) Video...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Blank screen when I turn it on... dont know what to do
May be a bad video card or it could be the screen went out
Dec 07, 2008 | Toshiba Satellite U405-S2820 Notebook
Screen problem for Nokia 6126
Are you certain you have a strong GPRS signal? Have you tried turning the phone off for a few moments and then back on, and also make sure you have good signal strength at the time you are trying to send an MMS.
 It could be due to network problems as well - the few times I've experienced it, it has lasted for several days and then it has been fine after that.
Nov 22, 2008 | Nokia 6126 Cellular Phone
NO signal error
Hi sir,
Hope this will give you ease of mind and or hints. The No Signal error screen message is normal it depends how much delay it responds to (design or default time delay) the video card down to CPU and control units. The blank screen can be resolved by turning off the screen saver(s) you have and even to BIOS mainboard setting; disable the "turn off monitor after how many seconds" or related menu, etc.. Hope you can manage to enter BIOS maiboard setup.
Best regards,
Rosener Guyano
Jan 30, 2008 | ViewSonic VP171s 17" LCD Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
Computers & Internet Logo
260 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
