Hi. I have panasonic DVD recorder, model DMR-E95H. Every time I try to play a disc or something from its hard drive, it goes into "start up mode" and keeps repeating this till I disconnect it from the mains supply. Also, you cannot get the disc out!! Any advice? John
  • 2 more comments
  • jpa1 Aug 26, 2008
    The problem only appears to exist when a disc is inserted
  • jpa1 Aug 26, 2008
    Yes.Can power down by pressing power button for 10 seconds but drawer will not open by suggested method. It just goes back into repeated SELF CHECK mode!
  • jpa1 Aug 26, 2008
    As the unit has enough power to keep repeating its SELF CHECK mode it does not appear to be a power level problem. Any other solutions? Could something just need cleaning?
  • jpa1 Aug 26, 2008
    Holding up/down keys has no effect. will not go into reset mode of any kind
  • 1,031 Answers
Check this http://service.us.panasonic.com/OPERMANPDF/DMRE95.pdf for a comprehensive operational and service manual that will guide you on it hope this helps
Posted on Aug 26, 2008
  • 157 Answers
The problem is usually due to corrupt firmware on the DVD player. You'll need to get it serviced as the service centre will install the upgraded firmware and problem will be solved.
If you search google, you may find some firmware updates
Have a read of this which explains how to upgrade the firmware http://panasonic.jp/support/dvd/download/e95h/step1.html
Hope that helps
Jigsaw
Fixya Team
P.S. Dont forget to rate this solution as FixYa !!!
  • 4,472 Answers
How long have you owned the unit? It sounds like your best bet is to have it serviced.
Here you will find the information:
http://www2.panasonic.com/consumer-electronics/support
Thanks,
Lee
    Master:
  • 848 Answers
Try to reset the unit
Hold down the channel up and channel down keys together, you MUST hold
these keys down until the clock starts flashing (not until unit says BYE)
keep them depressed until clock is flashing 12:00am.
Pull power cord on unit (15 -20 seconds) and re connect.
At this point the front of the recorder will show PLEASE WAIT (with no
hash marks going back and forth) wait until this goes off completely. The
front of the unit normally will be all black (no lights) this sometimes
takes a while.
Power the unit on, you may get one of two things, 1(Please Wait with
the flashing hash marks for a while) or just have front of unit display
GUIDE along with ch1, on the face.
The very beginning TV Guide set up screen on your TV, this is the
picture of a TV set with welcome to TV Guide set up. This means the
recorder is completely reset to factory, if you have the TV Guide screen
asking if settings are correct, you have not completely reset and must try
again.
    Scholar:
  • 93 Answers
1. Try to Re-seat the DMR-E95H Drive that means upplug and replug the drive
2. Then Go to the BIOS of the system and do the factory defaults.
3. Go to the device manager and remove the drivers and update the drivers and the firm wares
  • Sean  O'berion
    Sean O'berion Aug 26, 2008
    OK!! the Solution I found is
    http://www2.panasonic.com/webapp/wcs/sto...
    Version:
    DR-070
    Models:
    DMR-E95HS
    Instructions:
    Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs.
  • Sean  O'berion
    here is the correct Link
    Click Here
  • 4,234 Answers
Based upon your description, I would look at the power supply area. If the voltage levels drop enough, the unit will behave like the power has failed and freeze until a power reset occurs. WIth a disc inserted, there is more draw on the power supply circuits. If you feel comfortable opening up the unit and it is NOT under warranty, look for any capacitors that have bulged up on the top. That is one possible sign that there is a problem.
Keep us posted.
Dan
  • ABRsvcs Aug 26, 2008
    You don't understand what I mean by power levels. The COU chip inside the unit that controls all functions is sensitive to the 5V internal power level. If that starts to fall because of a loading problem within the power supply, the unit will go into self-test. This usually hapens at about 4.3V or so. This could be a bad voltage regulator or bad cap or a number of other things. Since the unit seems to function without the disc, it suggests a loading problem. I have 100s of these units here and have seen this before. The self test loop will continue until a hard reset otherwise known as a power down/up cycle.
    Dan
  • 6,487 Answers
You can try to open it but you would have to take off the facia, hard drive and just about everything else to get at all the screws on the outer black casing.
Try this also hold the power button down to force it to power down, and then with alot of experimenting, press the drive switch button at a certain time.
Later read online that "pressing the ON button for 10 seconds to force standby mode and then holding stop and channel-up together for 5 seconds should force the disc tray to open"
Hope that helps........
  • 2 more comments
  • Mark Gil
    Mark Gil Aug 26, 2008
    Because I think its still finalizing the disc and it may take a few minutes before its done,, because if its not yet done finaliozing it will just continue spinning, but it shouldn't take that loing, if it take for about an hour there's something with it and better take it to repair center near you,,,,,,,,,
  • Mark Gil
    There's already a mechanical problem with the player, so if you have knowledge in this kind of device you can open it up and check the mechanism inside it , that should fix that problem but there's some parts that needs to be replace better let a technician do it for you,....
  • Mark Gil
    yes, it can be a solve by opening the nuit and cleaning it from the inside , check also the drive mechanism why its not ejecting when you press the eject button , then when its done if you have a CD cleaner try running that also to clean the lens of the player...
  • Mark Gil
    Good luck............
    Master:
  • 763 Answers
To remove your disc find something like paper clip and unfold it and make a stick like. then use it for removing your dvd disc by inserting the paper clip stick back and forth until its open. you will feel a switch inside it. if that device is still on warranty then send it back to the place were you bought it and ask for replacement or repairing.
CHARCOIS
  • Charris Suaybaguio
    Charris Suaybaguio Aug 26, 2008
    by the way the location of the hole was in the lower of the dvd interface front panel. insert the paper clip stick like on it.
    Guru:
  • 1,894 Answers
If there is no disk in unit does this kind of problem come?
    Genius:
  • 1,847 Answers
Is it playing the disk or the only issue is you not able to take the disk out.
  • Legin Varghese
    Legin Varghese Aug 26, 2008
    To take the disk out the only way is to open the top cover and you can take the disk easily.
Panasonic DVD Video Recorder DMR/E95H, have no manual working instructions can they be down loaded
Hi
You can download the user manual for your DMR. Just enter into the folloing site and download it for absolutely free.
www.retrevo.com > ... > Panasonic DVD Players Manuals
OK.
Jul 08, 2011 | Panasonic Televison & Video
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
DMR-E95H doing self check for up to an hour
Your problem may be Panasonic's common capacitor failures. Open case and look for capacitors with bowed out top and yellow substance. Replace both with higher rated capacitors from Radio Shack. Will need some soldering skills. Look on this site for "solder c1260 c1261"
Sep 01, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Mar 13, 2008 | Panasonic DMR-E95HS DVD Recorder
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
Oct 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DVD problems
sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
May 15, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
