Question about Hitachi DZ-GX20A DVD Camcorder
I can't see the SD drive icon on my desktop.
Why don’t I see the SD drive icon on my desktop?
    Master:
  • 473 Answers
No connection --- Simply connect USB cable between DVD Camcorder and PC. No power --- Simply turn on. Mode switch is not SD mode --- Simply set the mode switch to SD mode, not Movie or Photo mode.
Posted on Sep 05, 2005
SOURCE:
Want to put music from my PC to my SD Card and don't how to do it. Can you show me how?
Get the external card reader and connect in desktop machine or laptop. Insert the SD card in external card reader and browse the SD card content in My Computer. Choose & copy the files, data, music files in local drive then paste the data in the SD card.
Dec 30, 2011 | SanDisk 4GB microSDHC Memory Card
I have an Inspiron one. Normally when I put my SD card in it pops up an option to import the photos. Today, I put my SD card in and nothing. So I don't know how to import my photos.
Click to the "Start" icon on the bottom left side of your desktop and click on "Computer". A menu will open showing the storage devices attached to your computer. You should be able to click on the SD device to open.
Jul 02, 2011 | Computers & Internet
How do I use the Micro SD port?
hi.
sd port is use for read yr sd card.. put yr sd card in sd port then yr can read it from clisk my computer icon and ten yr card will be locaten in g/h/f or try click 1 by 1 memory stick drive
regards
Feb 21, 2011 | eMachines Desktop / AMD Athlon Processor /...
Hi Sir, I have a problem with my SD Card when im going to read it on my pc. It ask for "format the disk before you use it". When I click cancel, it says"your volume not contain...
Does the SD card have pictures on it? What is the camera model used with this card? Have you tried connecting the camera itself to the PC in order to transfer the card's contents?
Dec 17, 2010 | Computers & Internet
I'm unable to format my 4gb Sandisk High Capacity SD card. The response I'm getting is that the disk is write protected.
Hold the SD card so the label is upright and facing you. Locate the switch on the left side and slide it up to unlock it. If you have a Micro SD card, put it into an SD card adapter. Slide up the switch on the adapter to unlock it.
Insert the SD card into your computer. If you do not have a built-in SD slot on your computer, then connect it with a USB adapter.
Open the Computer icon on the desktop. A window will open with a list of the available drives. Locate the drive the represents the SD card. The name of the drive may differ depending on you named it, or what the default name is.
Right-click on the drive and select Format. If it asks what you would like to format it to, select "FAT32" and click Start.
Oct 23, 2010 | SanDisk 4GB microSD High Capacity Memory...
Sd don't work
Hi:
Does your SD card reader show up as a drive when you go to : "My Computer" ? if it does, insert your SD card again, and see if the pictures are veiwable when you double click on the drive icon.
If the drive is not showing up in the my computer page, the driver might not be installed or the actual drive might be dirty or defective. You can check this by going to "control panel" , "system", and then "device manager." The SD card device should show up without any yellow exclamation points by it. If any devices have exclaimation points by them, you need to research what they are and find the proper driver for them to work.
Feb 10, 2010 | HP Pavilion Elite e9180t PC - 3.00 GHz;...
I am not literate, got a 1GB SD Card - do not know how to download on it - there are no instruction - help
Just attach your card to pc through card reader ,than automatically you will see a drive icon for the sd card when you open my computer ,now select the files than right click you will see dialogue box select copy ,now go to my computer double click on sd card and than right click and select paste ...that's it
Was this solution helpful .Show your appreciation by rating it.
May 28, 2008 | Compaq Presario 5000 PC Desktop
Connecting to my E:\ drive
Hi fantisy, It's not uncommon for your DVD player to not have the drive letter you were expecting it to have. Let me show you. Place a CD or DVD in to your cdrom drive, close the drawl. Close any windows that may open Ok here we go. Right click once on the Start button, than slide up to & left click on Explorer. Take a look at the icons. Left click once on the - sign to the left of C:
The icon you see to the left of C: is a hard drive. Look down to your DVD drive, see the differance in the icon, (a cd on top of a hard drive icon). Your E-Machine also has a SD card reader. Each card slot also shows a hard drive icon. So drive D: is your DVD player & F, G, H & I are SD card reader drives. Windows just skipped letter E.
You can re-assign your drive letters through windows Computer Management. Type Computer Management in your help window. Under Overviews, Articles and Tutorials, is Using Computer Management. Clcik on it.In the right half of help click,
Open Computer Management (Local).
Once opened click Disk Management. Here is where you can re-assign drive letters.
( DO NOT ) change C: drive letter assignment.
Enjoy!
Mike
Mar 31, 2008 | E-Machines T5082 PC Desktop
Aspire 3690 built in card reader
It should show up as a removable drive in "My Computer", and you should be able to copy files to and from the sd card. If it doesn't show up then your card may be broken, so try a different sd memory card. Also, make sure its the right slot and that the device drivers are up to date.
Jan 07, 2008 | Computers & Internet
Can't see the DVD camcorder icon on my desktop.
No connection --- Simply connect USB cable between DVD Camcorder and PC. No power --- Simply turn on. Mode switch is not DVD mode --- Simply set the mode switch to Movie or Photo mode, not SD mode. The wrong UDF device driver, other than the one provided with the DVD Camcorder, was installed – Simply install the UDF driver that came with DVD Camcorder.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Hitachi DZ-GX20A DVD Camcorder Logo
88 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
