Question about Sharp Microwave Ovens
Have a sharp microwave and convection oven combination and it will only run a few seconds and stops hit start will only keep running by hitting start. model # r1870
  • 5rustyj Sep 02, 2008
    it stops after 59 seconds and you hit start
    after each 59 seconds and you keep doing this until the food is done,also when you use the popcorn cycle it runs for a little bit and it comes up sensor and error and have to completley restart
  • William Miller
    William Miller May 11, 2010
    Does it stop after 59 seconds or some other amount of time?
  • Sharp Master
  • 9,098 Answers
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
If you only need a switch, you can order one from us for $5 postpaid.
Posted on Sep 02, 2008
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
I have a sharp model 1874 when you punch in the mintues it will only go to 59 seconds and shuts off. if i hit 10 mintues it will stop at 9:01
change damper motor and switch. cost is approx $30.00. unit must have cover removed to gain access to motor & switch
Dec 15, 2009 | Sharp R-1874 Convection/Microwave Oven
On convection or convection/microwave it runs for
Here is a link to your manual that you can copy and paste in your internet address bar;
Oct 10, 2009 | Sharp R-303CW Convection / Microwave Oven
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp 930 AK Convection/Microwave Oven
When you close the oven door the latches operate a couple of interlock switches that control power. It may be that one of the door switches is bad or out of adjustment. It's also possible that one of the door latches is broken so it's not hitting the switch. There should be two door latches. Are they both there? This oven could be fixed by adjusting or replacing the interlock parts as needed. Because of concerns about microwave leakage from an improper door seal, you should have this oven serviced by a professional.
May 21, 2009 | Sharp R-930AK Convection/Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave Ovens Logo
104 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
