Question about Phase Linear UDV9010 Car DVD Player
No video my dvd player comes on but when i put in a dvd disc. in, the video does not show.
    Sergeant:
  • 241 Answers
I have a in dash DVD player too
Did you try view a MOVIE while you were driving
if not check the wire that connects to the park brake FUSE
it is located in the (fuse Panel of your car) check it make sure that it is not been pulled out or loose and check th fuse that it is it too to see if it is blown. If that doesn't work you remove the car battery cable to resest it or the RADIO memory fuse inthe car panel.
Or if it was installed by a PROFESSIONAL they should of tapped into the parking brake line..it is also located near the fuses.
And if this keeps happening the newer dvd players are set to have this saftey feature so YOU DO NOT WATCH MOVIE AND DRIVE.
BUT sure you could just put a toggle switch on the wrie that connects the parking brake and BYPASS IT ;)
Posted on Aug 29, 2008
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
I have an older DVD player. COBY DVD-404. I downloaded pictures from my camera to my computer onto a DVD-R disc and then again onto a DVD+RW disc. Neither disc would play on my player. It comes up on...
Your 'old' DVD player is the problem. It is unable to 'read' picture files. Time to put the COBY away and upgrade to a DVD player that can read .jpg, .jpeg images. Most new players do and they are not that expensive.
Aug 11, 2010 | Computers & Internet
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
When disc is inserted, the window show loading for about 60 seconds, then tray comes back out. have tried all type of discs, same result. the vhs side works fine.
TRY A LASER LENS CLEANER IT IS A DISC WITH TWO PIECES OF LIKE FELT ON IT SHOULD COME WITH CLEANER JUST PUT IT IN AND PLAY TO CLEAN THE LENS IF THE LENS IS DIRTY IT WILL ACT LIKE ALL CDS ARE TO SCRATCHED TO PLAY
Jan 19, 2010 | GoVideo Go Video DVD/VCR Combo
New Go.video R6530 put DVD+R disc in shows no disc
you can only use imation or verbatim DVD+R. No other DVD's will work. I use exclusively the IMATION DVD's. Easily recognized by the logo on the disc package, it looks like the old movie reels.
Jun 17, 2009 | GoVideo R6530 DVD Recorder
Any disc put into dvd player shows up as BAD DISC
your DVD player lens needs to be cleaned by a lens cleaner...
Feb 09, 2009 | Conia DVD8500 DVD Player
Disc stuck in player.
Turned vcr player upside down and with a little maneuvering the disc came out.
Nov 17, 2008 | Sylvania SRD3900 DVD Player/VCR
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Phase Linear UDV9010 Car DVD Player Logo
78 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
