Question about Casio Cassiopeia E-10
E-10 Upgrades??? Hi, I just bought a Casio Cassiopeia E-10. I wanted to know if there is any way to upgrade to a new version of CE and install Pocket Word, etc. Any information would be greatly appreciated. Thanks __________________ Jason
4 Suggested Answers
vega
  • 551 Answers
SOURCE: Could someone help me please? (Newbie Alert!)
There are several types of processors used - find out which yours has and be sure the software will work on that processor. ARM SH3 Mips are the three as I recall. I have three hand units and two different processors.
Posted on Sep 05, 2005
SOURCE: Casio PV-S400 Software for my Microsoft Windows XP version 2002 Laptop
Depends on your operating system.
casio pc sync for windows is what you need
http://world.casio.com/pv/download/en/
Posted on Nov 02, 2007
  • 4 Answers
SOURCE: Casio Cassiopeia E-125 Pocket: Problem
low batteries.
Posted on Jan 01, 2008
SOURCE: Trouble with installing Windows CE
You do not install Windows CE, it is built into the Cassiopeia. What the CD is is the software for your computer to interact with the Cassiopeia.
You will want http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Posted on Mar 14, 2008
0 characters
1 Points
Help!!!
The BE300 uses PC Connect and will not work with Activesync. All the original software and upgrades are available at www.be300.org
Dec 12, 2007 | Casio Cassiopeia BE-300 Pocket PC
May 08, 2007 | Casio Cassiopeia E-100 Pocket PC
E-125 Will not power up ??? HELP
i made a video how to fix your dead Casio Cassiopeia PDAs.
AFAIK it works on the following models:
Cassiopeia E-10 (AFAIK)
Cassiopeia E-11 (AFAIK)
Cassiopeia E-15
Cassiopeia E-100
Cassiopeia E-105
Cassiopeia E-115
Cassiopeia E-125
Cassiopeia E-55 (= Japanese Version of E-15)
Cassiopeia E-5xx (Japanese Versions of the E-1xx Series)
Maybe it's also applicable to the EM-500 and EM-505 ...
and read the description pls :)
http://youtube.com/watch?v=l0TT5CnbwBQ
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Flash (.swf) on my E-100
AFAIK, Flash Player is only available for genuine (or upgraded ) Pocket PC's (2000 /2002).
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Casio e-11
Compatibility for these devices will depend more on the version of CE than the hardware. I have successfully tried a few with E-11.
Sep 06, 2005 | Casio Cassiopeia E-115
E 115 and windows ce?
Tascal software has a software for changing the wallpaper on the CE devices. File name is wpc032mp.zip. Try it.
Cannot start communications with the desktop computer
I have connected XP machine with Active Synch 3.1 to a wide range of E series Cassiopeias including E-15. The installation on XP is different from all previous versions of Windows. Without installing Active Synch you have to connect the switched on device to your PC & let XP find the device & install its own internal driver/service. Reboot the PC. Next install Active Synch - any version which should now find your device & start the service & establish your connection.
Sep 06, 2005 | Casio Cassiopeia E-15
Need your knowledge base
Were you able to access your mail with the earlier CE 2.11 version before the upgrade ? I too am using a rom upgraded E-105 I don't think it is a problem with java script issue since I have been accessing mail from my ISP both through the http ( online & browser) mode as well as the standard POP mode. My ISP is running strictly on UNIX & Java. Hope this helps.
Sep 05, 2005 | Casio Cassiopeia E-105 Pocket PC
Casio E-15 and Linksys WCF11
Well - if your PDA runs CE 2.11, it should install. Try downloading specific CAB file from Linksys's website for the MIPS processor (E-15 uses VR4111). If you have Linksys WCF11 card, go to http://linksys.com/support/support.asp?spid=71 If setup still doesn't work - copy a MIPS CAB file to your Casio via ActiveSync and run it from there. However, even after you install it - you might face problems. I still wasn't able to run my Linksys WCF11 on Casio E-100. Apparently, there is no easy way to specify IP settings (gateway, WINS, DNS) in Windows CE 2.11 for Linksys (unlike PocketPC OS, where we have network settings in control panel). I tried playing with registry - however, it messes up big time.
Sep 05, 2005 | Casio Cassiopeia E-15
Casio Cassiopeia E-10 Logo
18 people viewed this question
Top Casio PDAs Experts
k24674
Are you a Casio PDA Expert? Answer questions, earn points and help others
