Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Brown sticky spots
After washing a load of dishes, we found the dishes were covered with numerous brown sticky spots as well as inside of the dishwasher. We ALWAYS rinse the dishes before we load them in to the machine, it is very unlikely it was from the food residue, plus the sticky stuff felt like lubricant iol and very very hard to be cleaned off. It never happened before and our KitchenAid dishwasher is only one year old. Please help!
Katherine
  • Anonymous May 01, 2009
    same exact problem as described above, but my dishwasher is a different brand. what was the solution?
    Sergeant:
  • 409 Answers
Sounds like you have an oil leak from the motor/pump assembly. this should be covered under warranty by the mfg. have a technician replace the sump assembly.
Posted on Sep 13, 2008
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
There is a brown film all over inside of dishwasher. I have to put it on power scrub for my dishes to get clean.
I had a similar problem with my Whirlpool dishwaher, and it turned out that my water softener was not working. Once that was resolved, I found that I have to use a rinsing agent in the dishwaher to completely eliminate spots on the cleaned dishes.
Dec 03, 2010 | Dishwashers
Brown streaks on my clothes after washing them
O.K. Here it is, I solved it. After calling whirlpool who was of no help at all, reading all links about the Duet washer and/or the Duet dryer, I finally solved the problem myself. I too, thought it was the washer but, upon close inspection, found the felt on the dryer had worn out in one spot. The thin brown lines always showed up on whites and more so on anything very thin. I took the dryer apart and found a small burn line on the drum (brown and thin). I replaced the felt ($60) and used Simple Green to clean off the brown. Works perfect, no more thin brown lines. If you can't take the dryer apart, I called for repair and found the price with parts to average $250.
I was ready to sell the darn thing after it ruined about $300 worth of clothes. All in all, it's been three weeks and still working fine.
May 19, 2010 | Washing Machines
Brown spots on clothes from my maytag neptune
this sounds very much like that the bearings have badly worn-out,pain to replace them ?
Jul 13, 2009 | Washing Machines
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Brown material
I f you use liquid fabric softener you will get allot of weird things inside the machine building up and eventually falling off onto the clothes.Rust will also have the same effect,if you can see it ,sand it off ,and cover the area you sanded with a sealer and let dry for 24 hrs. Please Rate This !
Jul 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Oct 15, 2007 | Washing Machines
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
1,569 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
