Question about T-View T1501S 15 in. Car Monitor
Monitor not working
My tview 15 inch flip down monitor was down when my veh was hit in the rear. The monitor slammed shut when the impact occurred. Would this break my monitor and cause it to not work anymore. Is there any repair that could be completed to make it work again?
    Champion:
  • 232 Answers
DUE TO THE FACT THE TV UNIT IS FIXED TO THE INTERIOR OF THE CAR AND WILL ABSORB THE IMPACT AS WELL. ITS HIGHLY POSSIBLE THE UNIT WAS DAMAGED IN THE ACCIDENT, DO SOME BASIC TROUBLESHOOTING , CHECK THE HARNESS FOR DAMAGE, PLUGS AND FUSES BEFORE U FINALLY TOSS IT
Posted on Aug 28, 2008
What causes a Tview T244IR-BK not to power on when all fuses are good and where to buy replacement parts
That worries me when the fuses dont`t blow,otherwise I would have told you you made the wrong connections or did not ground enough. You can find fuses in any hardware stores and if your purchase is recent, have it replaced or get your money back. I suspect something wrong with the item. Or go to place where they are specialized in installing DVD monitors in cars; they`d tell you if it`s blown up or not. My TView monitor is really blown up and I am trying to find out if it can be fixed. My warranty has expired and I am kind of stucked.
Sylvain, Blainville, Canada
Aug 08, 2014 | Tview T244ir 24" Black TFT Wide Screen Car...
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
My monitor runs for about 4 seconds then blacks out. turn it off and on again an it comes on for another 4 seconds before blacking out. Any ideas? Larry
larryz 10, Did it work ok before this "black screen of death" started to occur?? Have you done any OS changes to the pc? Is unit still covered by warranty? Will "known good" old monitor work ok with pc? Have you performed the "flashlight test" that all cold cathode fluorescent lamp back-lit lcd monitor owners should know and understand the results of when black screen of death rears it's ugly head??? If BSOD not caused by software, could be problem with the monitor's internal "switch mode power supply/ccfl inverter supply" going into partial shut down (you see very faint image when flashlight is 1 inch from screen) or full shutdown ( no see image)!!! If +12v dc rail goes to shut down, then CCFL tubes will go off!!! No white light! If you do not know how the new style, screw-in curlie-Q, energy efficient, CFL light bulbs work, then go visit YOUTUBE for some video clips of ANY BRAND of CCFL back-lit lcd monitors having their SMPS/inverter supply being repaired. Remember this: Your lcd monitor isn't any different than any other brand in it's basic engineering design and mode of operation!!! If and when the "white LED" back-lit monitors hit the store shelves, then and only then will the CCFL electronic (600vac to 1000vac) ballast become history. Do some reading at this very old (2005) blog, even though not your model hp display. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ After you do your research, return here if you require more help or feel you have been helped by this response and would care to give it a rating on fixya. Good luck with the repair. 12fixlouie north of Windy City.
Oct 19, 2010 | HP Q1859 18 inch Monitor
No signal
This problem occurs from VGA cable or Video section.If it has warranty valid please replace it or repair it by a service center.
Dec 22, 2009 | MPC Computers Envision EN 5200e 15"Flat...
My monitor shuts down after the computer is left idle for 15 minutes. This is as part of my power management policy. But I dont know how to turn on the monitor after that.Even shaking the mouse doesnt...
there are two ways of taking your laptop out of hibernation.The first is to try and hit the enter key.If that don't work,hit your power button.Some laptops are different then others.
Sep 05, 2009 | Lenovo ThinkPad® T60p PC Notebook
Need a power plug for 17" tview flip down monitor
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Aug 03, 2009 | T-View T1045IR 10.4 in. Car Monitor
Upside down monitor
CTRL - ALT - <up arrow> should fix you up.
Mar 06, 2009 | Dell E153FP 15" LCD Monitor
CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Jan 18, 2009 | T-View TView (T606HR) 6" TFT/LCD Monitor...
Fujitsu-Siemens Monitor problem
MY LCD SIEMENS 15
I CONNET IT FROME POWER SPPLY (12 .V) IT WORKE BUT AFTER FEW MIANETS MONITOR ECIME WHIGHT WITH GROWPE LINES RED AND GOOWPE LINES BLUE COMEING AND GO QUKLY
Feb 24, 2008 | Mag Innovision LT776s 17" LCD Monitor
T-View T1501S 15 in. Car Monitor Logo
250 people viewed this question
Top T-View Car Audio & Video Experts
xxxxxx xxx
Are you a T-View Car Audio and Video Expert? Answer questions, earn points and help others
