Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Switching channels My Sony FD switches from v1, v2 and channel 52 after about 3 minuits after I switch it on and when this happen I losses all the fountion on the remote and on the control panel on the the set.
  • 41 Answers
The problem of your tv is the system ic that controls switching from switch... maybe it has a loose connection..
Posted on Sep 18, 2008
How do I fix a blown op amp on fender hot rod deville 2x12?
Unless the person that analyzed this problem used an oscilloscope and did detailed troubleshooting, I would NOT jump to the conclusion that aan op amp was blown BASED upon my looking at the schematic of the unit. There are MANY components involved with the overdrive channel, including relays and other transistors and components. The most probable caause would be that 1/2 of the V2 vacuum tube is burnt out. Test by swapping V1 with V2. If NOTHING works, then replace the tube that is NOW in V1 as the second section of it has a burnt out heater. Also a bad potentiometer for the OD channel would be a suspect. A VERY common problem is broken solder at pot terminals. Try plugging a set of headphones into the preamp output. See if you can hear sounds in bothe OD and clean channels. Note you will only hear sound in the LEFT headphone as the preamp out is MONO. MOST of the three op amp chips would NOT kill the OD signal if they were bad.
Sep 04, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Hi, I have a Deville 410 and my drive chanel is loosing volume but my clean chanel isn't. Are my preamp tubes going bad? Thanks, Aaron
The tube at V2 position, the "B" section provides additional gain for the drive channel over the clean.
It would be uncommon for this tube to go bad in this way so try this: Swap V1 with V2 and see if anything changes... if it does, replace the tube that was in V2... else there is something else wrong. Possible problems might be with the control pot for the drive gain or other components. The switching is done with relays and it might be that one or more contacts are not working in the relays. The job of troubleshooting gets deeper beyond this and if you are not adept at electronics best to take it in to a shop. There are lethal voltages in this so one has to be familiar with working on high voltage tube stuff...
Sep 11, 2011 | Fender Hot Rod Deluxe Guitar Combo...
No sound from tv channels but still getting sound from DVD movies; what's wrong?
Looks like switching IC problem. If you know repairing methods try locating the IC. search by the part No. of IC in Google. example- TC 4066 is a switching IC in some TV models. Look similar type in your TV.
Try accordingly after identification.
Jul 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Just bought a Sony XBR9 and Comcast gave me a Motorola DCT6200 box which has a DVI output to a HDMI input into the TV. When switching from a HD channel to an analog or digital channel, the picture is...
I am having the exact same issue. It started happening within the first few hours of turning on the XBR9 for the first time. I also have a Motorola box from Comcast. This did not happen with the HD TV that was hooked up previously. Did you return the TV?
Jan 07, 2010 | Arris DCT6200 DTV Receiver
I just purchased a Sony Bravia 52" 1080 HD 120 Hz flat panel and upgraded my comcast service to HD as well. At times, the "last" button will not work to switch to the previous channel or if it does, it...
If this is still problematic ask Comcast to service the problem and request one of the older, larger, silver HD with HDMI capable boxes. The other option is to use the component cable with the new boxes. I had the same problem and luckily a good technician who took his job seriously! I think I overheard him saying too that a DVR is an option as well, but you, if the technician doesn't offer, would have to state an argument for why you should not be charged extra for using one of those. Hope this helps? Nice to get to the root of problems! I'm keeping my fingers crossed because they had to order the older box. None were left in stock?
Jan 01, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Our TV shuts off when we are watching it. This
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Involentary channel switching
This is not an HD tv.Use the remote,came with the free rceiver converter box or pay tv tv box.
Nov 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Loss of one channel to speaker
when you say switching input wires you mean your source? that you switch it? you only have switch problem, it is mechanical type swutch need to clean only, if still possible. i dont know if you can find replacement.
Mar 21, 2008 | Audio Players & Recorders
Tv troubleshooting
your keyboard is most likley bad..or tv  buttons/switch...
Oct 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
