Car Audio & Video Logo
Posted on Jul 11, 2011
After replacing the battery from the car, the radio is requesting me to enter a code. But since it is a second hand car, I do not have this code. The make of the car is: 2005 Ford Focus Ghia.
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jul 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
1244
Points
21
Youll need to visit the dealership bring your registration to prove you are the owner of the car. The advisor will call Support to obtain the code. Wait you said ford. Im sure its the same.
2answers
How do I bring on the radio in audi a6 2002 model whn the battery goes off
Unfortunitly that radio requires a code that you enter thru the presets normally 4 to 6 numbers found in the original hand book that came with the car if not available youll need to contact the dealer an request code forradio an you will need the registration for car to prove it is your car might have to register it with the dealership be carefull not to put wrong code in more than 4 times it will be permanantly damaged due to antitheft feature built in to radio
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_c7b5aba9012a13b2
1helpful
Hi I purchased a Citroen Berlingo 2005 second hand.Radio needs cod, I don't have. Radio is a eurovox 3385 model no.MOD3385CIT1 serial no. 46000825.4. can anyone help.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Citroen service centre and get them to enter this code for you.
2answers
I replaced mt battery on my 2004 jaguar x-type and the radio is locked i bought the car second hand so i dnt know the radio code and the factory code isnt working. what can i do
Simple contact you local Jag dealership and ask them, they will need the VIN No and there is a small charge (about £8). Then follow the instructions on http://www.bluejag.co.uk to enter code.
2helpful
2answers
After changing the battery I lost the radio code and I don't know the number as I bought the Jaguar second hand
i have a 2004 jaguar x-type and i replaced my battery and the radio is locked and i dont know the code. i bout the car second hand and the code that the dealership has isnt working. what can i do to get the radio unlocked?
1helpful
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Replaced battery in 1996 Honda Accord which deactivated radio.
You need to code ..punch in code then power radio up and it will work. For a fee if its the original radio for this car the code can be retrieved by the dealer. If you entered to code incorrectly more than 4 times you will need to disconnect battery for 30 second and re-enter code. good luck and thanks for using FIX YA
4helpful
2answers
Audi tt stereo problem
Press and hold SCAN and RDS. 1000 will appear and you can enter your code using the station buttons 1-4 to set the digits.
Honda Civc 2004 radio code entered plays for 30 seconds and quits?
Not sure? If it is the wrong code it shouldn't work at all? Try leaving the radio on for an hour without doing anything and then re-enter the code. If that doesn't work, contact your nearest Honda dealer.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
