Question about Hitachi DZ-GX20A DVD Camcorder
How do I read the disc on a computer?
How do I read a DVD-R disc on PC?
    Master:
  • 473 Answers
• Windows XP Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as external DVD-RAM drive in Windows Explorer. DVD-R disc is read from the camcorder “ drive”. • Windows 98SE, ME, 2000 Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as two external drives such as a removable drive and a DVD drive in Windows Explorer. DVD-R disc is read from the DVD drive.
Posted on Sep 05, 2005
SOURCE:
I can burn to this disc a video from my computer and it plays back fine on computer from the disc but not in DVD player. Do I need a different type disc?
If the disc was written by your computer it would, obviously be able to read it. It may be that your pc dvd recorder takes dvd r+ discs but your dvd player reads only dvd r- discs. Google the make and model of your dvd player make and model with the word specification, or if you have the original instructions that came with it, look there for the formats it can read and obtain some of those. It is fairly straight forward really. You identified the problem correctly.
May 30, 2015 | Televison & Video
DVD WONT READ DISC ON HP COMPAQ nc6220
Was the disc made by someone or purchased from the store? Some players have a problem with certain dvds that someone made. Maybe your player can't handle the dvd format. Windows Media Player can't read all formats.
When you click Start/My Computer Is your dvd drive listed under my computer? If not, that's the problem.
Mar 31, 2012 | Computers & Internet
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
Jan 21, 2011 | Computers & Internet
CD/DVD Drive will not read discs
Did you check the specifications on the PC game? It is possible the DVD is bad; I have had brand new discs shipped directly from the manufacturer turn out to be unreadable. I would try it on another computer before I went too far. If you don't have one, try taking it to Best Buy or another computer store to see if they can read it.
Jun 16, 2010 | eMachines ET1161-03 PC Desktop
My gx270 is not recognizing blank dvd disc...how
make sure both the discs and the lens of the cd drive are very clean alot of the time any damage to either will make reading blank discs a chore for any computer
Apr 26, 2010 | Dell OptiPlex GX270 PC Desktop
Not reading DVD discs
has it been reading DVD discs before? Also, does it read other discs apart from DVD's?
It is possible that your DVD drive's lens (laser) is weak. You can try to use a lens cleaner or cutton board to clean the lens.
Take care.
Mar 07, 2010 | Acer Aspire One PC Notebook
Dvd will not burn to disc
replace the drive with a standby n see..
..contact ur System Admin/Vendor
Oct 27, 2009 | Compaq Presario 5000 PC Desktop
DVD's reading and writing problems
Two things you can check. First, whenever you burn a DVD or CD you must be sure to "close" or "finalize" the disc. Often this is done automatically, but double-check to make sure. If the disc was left "open" so that more files could be added later then it will probably only play on the computer that burned it. Second, there are some DVD drives that just won't read every type of recordable disc. Ask your friend to burn a DVD-R instead of a DVD+R and try to play it on your computer. Or, check if his DVD+R recording plays OK on other computers. If so, your DVD drive may be faulty and need replacing. Good luck.
Apr 11, 2008 | Computers & Internet
Won't play disc on computer, says it is blank
Perhaps your computer DVD cannot read DVD-R, DVD-RW. Newer DVD boxes can read both DVD- and DVD+, but older ones can only handle one or other format. I had the same problem and replaced the DVD in my PC with one that reads both formats and the problem went away.
Jan 07, 2008 | Canon DC210 DVD Camcorder
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Hitachi DZ-GX20A DVD Camcorder Logo
165 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
