Question about DFI NT70-SC Motherboard
Upgrading Rambus RDRAM
My motherboard is a DFI NT70-SC currently fitted with 256mg RDRAM. I would like to upgrade to 1Gb. Can you tell which RDRAM to go for. Will RDRAM PC 800-40 ECC 4x256Mb work?
Go for RDRAM PC 800-40 ECC 4x256Mb
Posted on Aug 26, 2008
    Scholar:
  • 62 Answers
I just need to upgrade the memory on a Dell Precision 530MT.. can't seem to find the exact type of memory it needs.. any ideas?
HELLO Paul
When installing memory modules in the system board sockets and not using the optional memory riser boards, observe the following guidelines:
  • Each memory socket on the system board must be occupied either by a RIMM or a CRIMM.
  • Memory sockets must be upgraded in matched pairs. In other words, two sockets in a pair must contain modules of identical capacity, number of components, and speed. See "System Board Memory Components" to identify pairs of sockets.
  • Mixed pairs of ECC and non-ECC modules all function as non-ECC.
  • Be sure to install a RIMM in socket 1 first (closest to the processor) before installing modules in the other sockets.
  • The system board supports PC600 and PC800 memory modules.
  • http://www.memoryx.net/precwor530.html what memory part numbers you should buy and cost
the link below will give you what type of memory you need to isntall
http://support.dell.com/support/edocs/systems/ws530/en/sm/2memory.htm#1149832
please rate my service
Nov 19, 2010 | Dell Precision 530MT (WHL530MTGHEI31LE) PC...
How do i install the audio drivers for this motherboard... and where do i get them???
The onboard sound card uses AC97 so windows update (custom install option) should find them. if not try cnet or here:
http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#AC
once you have downloaded them you should just click on the file to open it and it should self install. If not it would be a zipped file that will extract itself, so find the extracted files and click install.exe file in that folder
Jan 11, 2010 | DFI NT70-SC Motherboard
Hi I have a mother board EP-4T2A3 and it supports
This EP-4T2A3 is unique, that the can only utilize the slightly more expensive RDRAM memory modules. Furthermore, because of the dual memory controllers in the i850 chip-set, all motherboards based off of this chip-set must also have its RDRAM installed in pairs. You can purchase RAMBUS chips of PC600 to PC800 memory modules. You have 4 RIMM slots, and they must be installed in pairs, or you will get speeds of only a single module. The unfortunate part is that the RDRAM modules are a little more pricey. You can find some samples of these HERE.
Good Luck
Mark
Dec 29, 2009 | EPoX EP-4T2A3 Motherboard
When i plug in my memorycard adapter into the usb ports .the baloon says i need a hispeed usb host controller.
The memory card you have is for a USB2 configuration and the USB port configuration or port you are using is USB1 configuration.
Try a different port or check the manual for port layout or description.
Sep 26, 2009 | DFI WB72-SC Motherboard
I need to set up RAM on GATEWAY ATXAEG LX3 700S P04 for first time. What is the correct placement of RDRAM.
RDRAMs have to be installed in pairs (at least in my case I think) but can the two pairs be of different capacity? as in:
64,64 - 256,256
(Upgrading 2 64mb RDRAM to 2 256mb RDRAM)
Jun 16, 2009 | Gateway (4000782) Motherboard
I want to upgrade my procesor to faster procesor.
Upgrading processor is not likely a practical solution; find out the motherboard manufacturer and contact their site for more information. As to upgrading the motherboard, you'll have to know what kind/size of board your system will require. If you don't have lots of experience, this process is very risky.
Frankly, the cheapest way to upgrade your computer is to buy a used and working product with Windows XP already installed. Go to http://craigslist.com, select your city, and search for a brand name you trust. I've bought DOZENS of used computers very cheap that way (I'm writing this on a $2,200 Dell Latitude D620 I bought fiv months old for $500, who needed the cash!)
Mar 30, 2009 | Gateway Computers & Internet
Upgrading memory
pc 800-45 is also compatible. you can get that one.
Dec 18, 2008 | ASUS P4T-M Motherboard
What is the part number for upgrading the memory for my MS-6368 Micro-ATX Motherboard? Upgrading to 1GB
You can go to the MSI website for your product (http://www.msicomputer.com/product/detail_spec/product_detail.asp?model=VIA_PLE_133_5a_Lan#) , then click the link for memory recommendation, either Crucial or Kingston.
An easier method is to go to the Crucial web site (www.crucial.com) and run their system scanner. It will tell you exactly what's currently in your system, and options for upgrade.
Note: You must be running IE to use their tool, and you must accept installation of their Active-X plug-in.
FW
Apr 30, 2008 | Computers & Internet
Dfi wt70ec socket 423 board never used and visiontekx1300512mb agp
Either video adapter is not seated properly. Remove the video card & reseat.
Also, check to ensure the monitor cable is connected properly.
Jan 01, 2008 | DFI NT70-SC Motherboard
Memory Sticks.
No you cannot fit sdram, they will not fit. Go to the link below and it will explain what memory you have and if you use the pc to go to thie link there is a memory advisor tool to the right of the page which will search your pc and advise you as to what upgrade you can have. http://www.crucial.com/library/ddr_vs_rdram.asp
Apr 11, 2007 | Intel D850MV Motherboard
DFI NT70-SC Motherboard Logo
227 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
