Question about Hitachi DZ-GX20A DVD Camcorder
Do I have to use the round DVD holder?
Can I use DVD disc without the round DVD holder?
    Master:
  • 473 Answers
No, The round DVD holder is necessary for using on DZ-MV350 or DZ-MV380.
Posted on Sep 05, 2005
Do i need a cd holder for my dz-mv380a
Posted on Jan 27, 2010
SOURCE:
I NEED TO ORDER THE ROUND DVD HOLDER FOR THEDZMV550A HELP CAN IT BE USED WITHOUT THE HOLDER
To get any part you need for your hitachi camcorder call or go on-line to,Andrew electronic and they have everything you need. 1800-289-0300 or 800-289-0301 kentucky.good luck.
Aug 31, 2011 | Hitachi DZ-GX20A DVD Camcorder
Drawer jammed and disc got loose.Openned top removed disc.closed back up but still had a rattle. Open back up and removed a loose round piece about 1 inch in diameter. Seems to have broken off of...
The only 1 inch round disc I can think of is the CD holder mounted on the motor spindle. It would be helpful if you could mention make and model # of the player in question.bobhifi_11.jpg
Mar 11, 2011 | Televison & Video
Do you know where we can get a round DVD cartridge/holder for a panasonic M50? Ours was lost or missing the first time it was used.
I found DVD-R discs with holders on Amazon.com but after ordering find they would not ship to New Zealand.
I really want to get 1 or more of these holders.
john @ buzzwon2002@yahoo.com
Feb 14, 2010 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Wii would not eject disk so we took it apart and fixed it but while we were doing this a plastic piece fell out of the metal casing over the disk drive now we cant find where it came from so we are now...
what does this "plastic piece" look like??
that said.. I think its the magnetic disc holder (round- white- plastic- fits on a cd...)
, it sits on top of the disc drive in the round hole - it holds the disc to the motor when the disc plays...
You have to put it back in its holder above the disc, it goes on top of the "crossmember" if you put a disc in the drive and set the laser to lift up and grab the disc you will know if you have it right because the "plastic piece" will grab the disc and hold it tight against the motor.
hopefully this solves your problem... comment back if you need more info or if the p[iece isnt what I described and is something totally different.
Jan 21, 2010 | Nintendo Wii Console
My jensen touch screen cd/dvd player ate my dvd the longest yard lol. How do i remove the cd from inside the cd player without messing it up?
Turn the thing off, FIRST(!) (please). In the front of the CD holder (in the plate on the front of it) there should be a tiny hole, literally about 1mm diam. Get a paper clip, straighten it out, and then turn the end half-inch/cm over so that it acts as a handle. Now carefully push the other long straight end into the hole (possibly an inch or more), until it contacts something solid. Push it firmly but carefully and the CD holder should slide out. You may need one or two tries at this, but you should be able to do it without too much trouble. This is a recognised method of removing a stuck disc.
Dec 01, 2009 | Computers & Internet
Broken DVD holder/spindle
I have the same issue! if you get a solution please let me know!! I have searched every where with no success.
Feb 27, 2009 | Philips MCD703/37 System
Disc Loader got jammed.
Remove the top cover.  You will see where the disc are, take care in removing the stabilizer housing, you should be able to get the dvds out and put it back together.
Jan 04, 2009 | Philips DVP642 DVD Player
DVD holder tray in CPU unit.
This could be due to a sticky eject button on the front of the drive or a damaged PCB inside it. If it's the latter the only way around it is to replace the drive.
Mar 14, 2008 | Computers & Internet
My portable dvd says "wrong disc"
Your problem is either the laser Diode has faulted OR perhaps the Lens is "Dirty" it can be cleaned with a special "Cleaning Disk" but I would think unfortunately that the laser assembly has gone faulty, a common problem unfortunately :(
Jul 27, 2007 | Coby TF-DVD5050 Portable DVD Player with...
Which Hitachi models use a disc caddy to hold the DVD disc while in the Camcorder?
Current Hitachi Models use no disc caddy for the DVD disc. The 2003 and 2004 line of Hitachi DVD-Camcorders (DZMV350A, DZMV380A and DZMV550A and DZMV580A) utilize a round disc holder to accommodate the smaller design of the newer models. All previous generation DVD-Camcorders use a square cartridge. The actual discs are the same and can be used in all models as long as the disc is placed in the appropriate holder or cartridge.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Hitachi DZ-GX20A DVD Camcorder Logo
472 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
