Question about Hitachi DZ-GX20A DVD Camcorder
I can't charge the battary.
Why is the battery charging not working?
    Master:
  • 473 Answers
Disconnect DC power cable from AC adapter/charger. Battery charging will not be possible if the DC power cable is left connected to the AC adapter/charger.
Posted on Sep 05, 2005
Riding lawn mower battery won't hold a charge
It is a battary issue, however it sounds like the engine is not charging the battary so it goes flat, or there is a drain on the battary .
Jun 27, 2013 | Craftsman Garden
Battery drains while mowing - after about an hour I cannot engage blades if I stop mowing - I have to charge battery after each mow - Have changed battery thinking that was problem but it still continues...
Charging system on the engine is not charging, either the charging coil under the flywheel is bad, or the regulator is not working, you need to check what voltage/amps is coming out of the system, before doing thsi just check all the battary leeds are tight also the negative battary leed has a good earth at the chassis.
Jul 06, 2012 | Husqvarna 24HP 54" Yard Tractor ()
Sir, my laptop CompaqEvo610C can not charging i check my battary on other same model of Compaq it is working and good condition and give backup more then 1hour. when i put the battary in my laptop again...
Since you tried your battery on another pc, then try a different charge power supply on yours. You may have a bad power supply adapter or your battery terminals on your pc may be dirty and need to be cleaned with rubbing alcohol and a cotton swab.
Sep 29, 2010 | HP Compaq Evo n610c Notebook
I have a big problim with mt 91 honda accord my battary wount charge i put new altanater new battary all cables are great but it wount seem to charge the battary if i charge the battary it well last up to...
With the engine running are you getting any voltage off the alternator? check with a multimeter. Check voltage at battery while running should be 13 volts or more.
May 16, 2010 | 1991 Honda Accord
I have battry problem with nokia 6233 battary is bp6
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 12, 2010 | Nokia 6233 Cellular Phone
Hello i replace my small ups 650VA battary with a car battary,when i charge the car battary with an external charger does this affect my ups if it remain connected with the battary
Should not be a problem - just make sure the charger is a good one, and avoid over-charging. Once the battery is fully charged, the UPS should maintain it properly. Also, check the water level once a month - dry cells will kill the battery.
May 04, 2010 | PC Chips M871G Motherboard
I have canon zr800 camcorder,its battary not gatting charged.
can you try to used a new battery if it works i think your old battery have a problem.
thanks,
Jun 23, 2009 | Canon Video Cameras
I have q phone its battary doesnt take the charge
Check if its the right battery because it might be the wrong one
Apr 02, 2009 | Motorola Mobility Q Smartphone
Battary
It Prompts when Battery Low -
But U Havent Looked at it -
U Just might have put it to Cable to charge -
But it doesnt -
So Means u have to change Charger -
Be See that ur Charging socket isnt Loosened -
Then change ur charger with a Newer n Original
One -
Jan 20, 2009 | Cell Phones
Hitachi DZ-GX20A DVD Camcorder Logo
216 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
