Question about Whirlpool Washing Machines
Door open light flashes as machine wants to spin/start drum rotation. Had this before when the brushes were worn down. Not this time, have checked brushes
    Genius:
  • 1,028 Answers
Possible door lock
Posted on Aug 28, 2008
Loud noise in spin cycle
Could be the bearings.could be the belt. Could be the motor brushes.one way to point to bearing faults is to check for play when the machine is off.open the front door and see how much the drum displaces when moving it up and down.rotate by hand and it may replicate a grinding noise.if it feels quite tight then go onto inspect the motor area.if there is lots of carbon dust then it is more likely the brushes have worn to the metal sheath.cheap to replace.Complete refurb motors for most machine on eBay £30 + postage...also check the belt for wear against housing and springs which hold the concrete block in place.
Jan 26, 2015 | Whirlpool Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
The drum wont rotate, is it belt driven from the motor, if so how do you get in to change? cant get lid off
take the back panel off to get to ure belt, but first put ure hand inside ure machine n spin the drum if there is no strain wen tryin t spin the drum n the drum feels very light to spin ure belt has snapped if there is abit of strain u will need ure motor brushes changing
Feb 03, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
The door lock led stays flashing even after machine is turned off
Control module probably faulty, this could have failed due to motor problem check for worn carbon brushes in motor.
Oct 29, 2008 | Indesit WA 115 Front Load Washer
Drum Does not Rotate
the carbon dust that you mention ? on the drivebelt will//may have come from the electric motor carbon brushes especially as you sy machine is 4 yrs old you can diy inspect the brushes by removing the rear panel to access motor unplug the socket from motor then slacken belt and remove belt from pully remove the motor you will see location f brushes x2 opposit each other and normally held in position ont armature of motor by coiled pressure clip like watch spring and brush has wire embedded in it and other end a push on terminal? when these brushes wear down normally the fist indication is fast spin slows then eventually no rotation of drum? over a period of time? SO easy diy to renew brushes if as above worne down /not contacting armature? cost approx £5 here in n/west uk worth investigating and diy saving ££££s $$$$s? and i hope you have good luck hope this helps/inspires you?
Oct 26, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by...
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Jul 20, 2008 | Whirlpool AWM6120 Front Load Washer
My Bosch washing machine drum does not spin at all
No, there is no rotation on the drum at all tresilla.
Jun 21, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Whirlpool washing machine
Hi, I have the same problem with the same machine! I've tracked it down to a broken belt.
Jan 15, 2008 | Hotpoint WMA40 Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Hoover Vision 1600 drum not spinning?
Have the same problem, different model and it looks like I am outside 5 years spare parts. Probably just a belt or something from overloading. Also looks like it would nearly be cheaper to buy a new machine.You must have checked your pump???? What a rip off
Nov 27, 2006 | Hoover HF7 160E Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
